03-23-2021, 01:21 PM
digitalpost08 digitalpost08 is offline
I have Windows XP Pro SP2 installed on an old DELL Dimension 4300 using VirtualDub. Trying to get an ATI TV Wonder HD 600 USB to show both the left and right audio but am only getting the left channel to work. To confirm this was not a problem with the output from my VCR I plugged in another audio source with the same result. (Using an audio tape deck) I had first tried this on an install using Windows XP Pro SP3 and thought it may be worth a shot to try it on SP2 so reinstalled windows. Before the reinstall I did also try a capture using VLC from the ATI TV Wonder with the same results, only the left channel audio recorded. Maybe an issue with the driver I'm using or maybe my ATI TV Wonder is just busted? Any suggestions would be appreciated. In the screenshots I've attached it shows that the Catalyst Install Manager fails to install but I did not think that was critical in what I needed from this.
03-27-2021, 03:05 AM
This is not a driver issue.
You have missing audio. Either:
- AV cable on the ATI is defective
- RCA audio cables defective
- VCR output defective
ATI CMC not installing is likely not related. ATI CMC doesn't report dropped frames for the MPEG, and is mostly useless as a result. It's software MPEG capture, not hybrid hardware like the AIW AGP/PCI, which uses MMC with the proper counter. This card is ideal used for lossless in VirtualDub.
The following users thank lordsmurf for this useful post: digitalpost08 (03-27-2021)
03-27-2021, 06:01 PM
Thanks lordsmurf. I ended up using an old soundblaster card to capture the audio and it seems to work alright. I've ordered a another ATI TV Wonder HD 600 USB so I'll see if the A/V cable included with that one works any better. If that is the case are you aware of a place online I can get a backup A/V cable that will fit that port on the ATI TV Wonder HD 600 USB or are those a package deal? I found that Hauppauge makes one similar for one of their wintv units that looks to have the same port. Just has a ferrite bead inline. Don't know if that would be an issue?
https://www.hauppauge.com/pages/webs...r_avcable.html
03-27-2021, 06:11 PM
Ordered from where? Realize that lots of defective and incomplete capture cards are sold on eBay. Most people do not realize the issues until after the return window, because video capture isn't a simple task. BS like that is why I started to provide capture cards on the marketplace subforum here several years ago.
I have a stash of extra cables.
03-27-2021, 06:35 PM
I purchased from ebay.
ati tv wonder 600 usb
Audio crackling sound in VCR right side only? bakerie Video Hardware Repair 1 03-31-2020 03:46 AM
JVC SR-MV45 distorted audio when playing linear audio on SLP tapes? ChunkDaMan Capture, Record, Transfer 17 08-12-2019 04:55 PM
Chroma bleed problem, left and right? Spotty Restore, Filter, Improve Quality 9 01-13-2019 12:23 AM
FYI: Still two JVC-SR-V10U left on eBay! JT_too Marketplace 3 02-04-2013 05:23 PM
MPEG not playing on Premiere 6.5 - jittering video no audio morsagmon Edit Video, Audio 1 04-18-2011 07:59 AM
