10-04-2021, 04:51 PM
mikenew02 mikenew02 is offline
Panasonic AG-1980
This starting happening all of a sudden and it is affecting all tapes and speeds.
The width varies but it is always in the same position.
10-04-2021, 05:14 PM
Davis Davis is offline
I would be sure the heads are clean, but also make sure there is not some oxide build up elsewhere in the tape path especially around the head drum area. Keep us posted.
10-04-2021, 06:27 PM
Luckily nothing serious. I jiggled with the circled part, back tension lever I believe, and it fixed it. Loose tape I guess.
10-04-2021, 07:12 PM
Make sure that tension lever moves freely, I would put a dab of oil at its shaft where in swings on the chassis, that would free up any crust buildup there and your tension will back to normal.
10-04-2021, 08:22 PM
Those screen caps are seriously overblown values.
Either
- bad source tape, overexposed source (unlikely since TV)
- bad caps on the deck
10-04-2021, 08:59 PM
I think they're fine. Face/Off was graded that way for the flashback.
Here's some more, including a comparison with an existing YouTube video - mine is much less saturated.
10-04-2021, 10:21 PM
Yours isn't really less saturated. It's overexposed. The whites/highlights go hot, colors drain.
That points to a caps issue.
How does it look with both TBC on and off?
10-04-2021, 10:34 PM
Oh, I see what you're saying. It looks the same on or off.
10-04-2021, 10:39 PM
That's a caps issue. I have the same problem on a unit here. Too hot, needs refurb.
10-04-2021, 10:49 PM
Do you happen to know which area of the board these caps are at?
10-04-2021, 10:51 PM
Mostly TBC board, but can be others. And then you probably need to adjust the pots.
Horizontal line artifacts every 3rd frame? vhsnewb Capture, Record, Transfer 9 07-16-2021 09:14 PM
Horizontal shaking line noise going from bottom to top retractOffer Capture, Record, Transfer 6 04-13-2020 07:10 AM
What causes this thin horizontal white line noise? dima Capture, Record, Transfer 12 01-24-2020 10:02 AM
Diagonal line noise on VHS video? Luma noise? bilditup1 Capture, Record, Transfer 66 10-17-2015 01:03 AM
Jittery horizontal line in middle of screen Kereellis Restore, Filter, Improve Quality 6 06-25-2010 05:32 PM
