10-07-2021, 05:10 PM
rprilenski rprilenski is offline
See attached image. This is the only tape that does this and playing it on other VCR players yield the same result. The left side edge of the video has a purple-bluish haze and the right side edge is black and white/grayed out. Is this a sign of tape degradation or faulty recording with the video camera etc? The tape is a Memorex Pro Series T-120 that is from 1985.
File Type: jpg 5A1AB16D-7550-4AC4-A1CA-54DED7FD1E7A.jpg (83.9 KB, 21 downloads)
10-09-2021, 08:57 PM
It's mostly in the overscan anyway, so not worth correcting. Just mask and move on.
I've seen technical explanations of why this happens, both in this forum and at VH, but it's really nothing more than trivia. Certain decks may be able to stave off the noise from leaking as badly into the image, but not by much.
The is something that happens at record time. Not at play, not a degradation.
It's a chroma artifact.
Why does video capture change to green and purple? ThumperStrauss Capture, Record, Transfer 1 06-14-2021 07:07 AM
Problems with Elite Video BVP-4 Plus, lines on side of video? Dallas Video Hardware Repair 6 06-13-2021 06:11 PM
RGB Histograms - Red and Blue Riding Up the Side? koberulz Restore, Filter, Improve Quality 3 07-01-2019 06:11 PM
