04-16-2022, 03:29 PM
Following a PAL VHS capture using VDub 1.9.11 to a Lagarith Avi file I am using AviSynth to slightly adjust Levels and noticed in the histogram some spikes in the luma.
Are these spikes a tell tale sign of something not right in the capture?
04-16-2022, 04:09 PM
Probably the infamous auto gain control (AGC) kicking in ? whatever card/ dvd recorder you are using try to disable it, always capture "flat".
04-16-2022, 04:50 PM
My hardware is VCR -> composite -> ES10 -> SVideo -> Diamond VC500USB. I have been careful to capture within legal range. The only setting I adjusted before capture was to nudge the Brightness value up (after temporarily cropping and viewing the histogram in VDub), on the ProcAmp tab.
On the ES10 I have Comb Filter On, DNR Off.
04-17-2022, 02:23 AM
What OS?
It's unusual for VC500 to limit the output to 16-235 for NTSC, but maybe this is normal for PAL? Been a long time since I've looked at people's PAL samples from one.
Histogram spikes typically happen when one adjusts the driver Proc Amp (aka VDub Levels) controls from default, but again I don't recall this being an issue with my own VC500...
04-17-2022, 05:52 AM
I am using Windows 10.
Lollo I was reading another long thread in these forums "My 2nd captures: Luminance levels, distortion?", where you advised never to expand the range using the software Proc Amp. I have just done another test capture with default Proc Amp, but still getting the spikes.
However, calling Histogram("levels") after QTGMC or TemporalDegrain2 appears to smooth out the Histogram. I'm not sure if that is only hiding the 'defect' and I should be obtaining a capture without spikes? Or if these filters should genuinely be used to resolve the spikes.
My VC500USB does occasionally limit capture to >16 in the VDub Histogram (and appears to affect the captured file), but this can be fixed by restarting the PC/unplugging and re-connecting it.
04-17-2022, 06:59 AM
Yes. My guess is the AGC activity. I also have spiky histograms, even at default procamp settings.
That's because during filtering the levels are expanded to 0-255 and dithered.
Capturing VHS/SVHS tapes is not a defect, but rather a "characteristics" of some cards, such as VC500 and USB-Live 2.
If you do not plan any restoration you can avoid the filtering if the only goal is to remove the spikes. However, a basic restoration if often needed (minimal denoise and limited sharpen) to improve your videos. But you can just leave the captures as they are, just mask the head switching noise.
Strange. No ideas here
04-17-2022, 04:36 PM
I have unplugged and reconnected the VC500 to allow it to capture within it's full range. My earlier attempt was done when the VC500 played up and created a hard border at Y=16. Someone else in these forums has mentioned this happens occassionally with their VC500.
Knowing now that there are gaps/spikes in the Histogram, even if leaving the VDub Proc Amp at default settings, I decided I would rather have correct (legal) levels as much as possible but without 'expanding' them for the capture. I have only adjusted the Brightness in the Proc Amp tab to shift the levels towards the right in the VDub histogram (with a slight overspill into the red at the left).
Having just recaptured the tape and checking in AviSynth using ColorYUV(analyze=true) it is showing min and max luma between 10 and 244 (after cropping 20 pixels off all borders). The Loose Min and Loose Max are around 20 to 230.
Is this the correct way to use Levels to increase the range:-
Levels(20, 1.0, 230, 16, 235, coring=false, dither=true)
04-18-2022, 04:43 AM
Once again, you should move (decrease/shift) the levels before capturing just to avoid crushed blacks and clipped whites, beeing these the levels that your card cannot capture, Y<10 or 14 and Y>254 (if they are present on the tape). You recognize them because looking to the Histogram you will see big spikes in correspondence of these values.
Good, you should have now a nice Histogram.
Is this the correct way to use Levels to increase the range?
No, there are several errors. First of all, you need to change the levels for 2 reasons: - to stay inside legal 16-235 levels before a YUV to RGB conversion; this beeing for example a processing in VirtualDub, a processing in AviSynth with filters using RGB space, or a play/display in RGB mode.
- to change the look to your personal taste or compensate a defect in the video.
In the first case, you shrink 10-244 levels to 16-235, considering mix/max and not loose min/loos max values:
Levels(10, 1.0, 244, 16, 235, coring=false, dither=true)
Some other manipulation is needed:
- at the end of the VirtualDub/AviSynth processing, generally the levels will be expanded by the filtering operations to 0-255. At this point is your decision to bring them back to 16-235 or not, according to your taste and your display options.
- the command "Levels" change the Y values, but also the U and V values, and then the colors. The chroma is almost never out its legal range. It's then better to use a modified command acting only on Luma:
function Levels_mod(clip c, int "input_low", float "gamma", int "input_high", int "output_low", int "output_high", bool "coring", bool "dither")
return c.Levels(default(input_low, 0),
\ default(gamma, 1.0),
\ default(input_high, 255),
\ default(output_low, 0),
\ default(output_high, 255),
\ default(coring, true),
\ default(dither, false))
function LevelsLumaOnly(clip c,
\ int "input_low", float "gamma", int "input_high",
\ int "output_low", int "output_high", bool "coring", bool "dither")
return MergeChroma(c.Levels_mod(input_low=input_low, gamma=gamma, input_high=input_high,
\ output_low=output_low, output_high=output_high, coring=coring, dither=dither),
\ c)
and then:
LevelsLumaOnly(10, 1.0, 244, 16, 235, coring=false, dither=true)
The following users thank lollo2 for this useful post:
London (04-18-2022)
04-18-2022, 05:08 AM
I have experienced this too with the VC500, mainly when switching between NTSC and PAL I think, and yeah replugging fixes it. The windows drivers for these cards are a bit janky in general for whatever reason.
Histogram having "spikes" is something that happens on many capture devices, not just this one. It's someting to do with how brightness/contrast settings are handled by the card as noted.
04-18-2022, 08:09 AM
If forced to do a YCbCr-RGB-YCbCr round-trip conversion, I would instead avoid expanding and then re-compressing the levels.
ConvertToRGB(matrix="PC.601")
[processing steps]
ConvertToYUY2(matrix="PC.601")
Swapping out ConvertTo YV16, etc. for YUY2 if planar is desired, and adding interlaced=true if a conversion involves 4:2:0.
lollo2 (04-18-2022)
04-18-2022, 09:28 AM
Yes, also possible
Edit: Levels add you the option to adjust the "look" on the fly if needed, although sometimes is better to do the brightness/contrast/color adjustemens after the filtering
04-18-2022, 10:00 AM
I should mention my final delivery is always H.264 in an MP4 container, produced using command line ffmpeg. I have a small PC connected to my Smart TV and use VLC to play all files. So I think I should always be aiming for broadcast levels 16 to 235 for my final output.
I have used the Minimum and Maximum luma values (10 and 245) in the Levels filter and things are looking better, but were still looking a bit compressed/'lacking in height' when viewing the Histogram("levels"). So I used Tweak to adjust the brightness and contrast to occupy more 'height' in the Histogram. The scene in the screenshots attached is difficult because of the window in the background, but do my Histograms look healthy here? Is it best practice to play with brightness and contrast until the levels are touching the floor and the ceiling in the classic histogram (waveform?) whilst ensuring no obvious clipping is occuring? This approach seems to bring out a richer picture.
From my understanding of the Levels filter I just need to insert the Minimum and the Maximum luma values obtained from analyzing the captured clip, leave gamma at 1.0, always use 16 and 235 for Output Minimum and Output Maximum respectively, always use coring=false and dither=true.
Also from my limited understanding of the Levels filter it would only affect the chroma if processing in RGB or altering the gamma value? My source is YUY2 and I am not making any conversions to RGB (as far as I can tell). No processing is done in VDub either.
Lollo thanks for the script but I could not understand how to use it AviSynth.
My script is this now, although I have to say I am not seeing any noticeable benefit of calling TemporalDegrain2 and LSFmod on this video, especially given the additional rendering time it will add. I have left them there in case you ca advise me if I have all fliters being called in the correct sequence.
SetFilterMTMode("QTGMC", 2)
AviSource("VHS.avi", atrack=0)
#AssumeFPS(25, 1, true)
AssumeTFF()
Trim(30,42624)
Levels(10, 1.0, 245, 16, 235, coring=false, dither=true)
Tweak(hue=0.0, sat=1.00, bright=-8, cont=1.10, coring=True, sse=False, startHue=0, endHue=360, maxSat=150, minSat=0, interp=16)
QTGMC(Preset="Slower", Edithreads=4)
Crop(14,0,-10,-12)
### ----------CROP TEMPORARILY FOR HISTOGRAM CHECK
#Crop(20,12,-20,-20) # HASH OUT THIS TEMPORARY CROP AFTER HISTOGRAM CHECK
ConvertToYV12(interlaced=false, matrix="PC.601")
#ColorYUV(analyze=true)
#ColorYUV(off_y = 0, off_u = 0, off_v= -5)
TurnRight().Histogram("classic").TurnLeft()
#Histogram("levels")
#l=Histogram("levels").Crop(width, 0, 256, 72).Subtitle("Luma")
#r=ConvertToRGB(matrix="PC.601").ShowRed().ConvertToYV12(matrix="PC.601").Histogram("levels").Crop(width, 0, 256, 72).Subtitle("Red")
#g=ConvertToRGB(matrix="PC.601").ShowGreen().ConvertToYV12(matrix="PC.601").Histogram("levels").Crop(width, 0, 256, 72).Subtitle("Green")
#b=ConvertToRGB(matrix="PC.601").ShowBlue().ConvertToYV12(matrix="PC.601").Histogram("levels").Crop(width, 0, 256, 72).Subtitle("Blue")
#StackHorizontal(last,StackVertical(l,r,g,b).AddBorders(0,0,0,height-288))
### ----------DEGRAIN
TemporalDegrain2(degrainTR=1, grainLevel=2, postFFT=1, postTR=1, postSigma=1.0, postDither=-1, postMix=0, extraSharp=false, fftThreads=1, debug=false)
### ----------ADD SHARPENING
LSFmod(defaults="fast", strength=100, kernel=11, preblur="OFF", secure=True, Szrp=16, Spwr=4, SdmpLo=4, SdmpHi=48, overshoot=1, undershoot=1, overshoot2=2, undershoot2=2, soothe=true, keep=20, edgemode=0, show=False, screenW=1920, screenH=1080)
### ----------CONVERT BACK TO YUY2
ConvertToYUY2(interlaced=false)
AddBorders(4,4,4,8)
Prefetch(14)
My ffmpeg line is now
ffmpeg64 -i "VHS.avs" -c:v libx264 -preset slower -crf 18 -colorspace bt470bg -color_primaries bt470bg -color_trc gamma28 -aspect 4:3 -c:a aac -b:a 128k "VHS.mp4"
04-18-2022, 11:22 AM
Yes. It is not mandatory for the histogram to extend to full width and heigth. Is must be appropriate for the kind of scene. You can add your "personal" taste if you wish, as you did.
The comand Levels() touch the chroma. If you do not whish so use YLevels() or insert the 2 functions I wrote in your script and call LevelsLumaOnly()
QTGMC at defaults level already denoise and sharpen. If you do not need TD2 and LSFmod it is ok, use them only when necessary (the less filtering, the best).
Your script is good!
Just remove the unnecessary ConvertToYUY2(interlaced=false) at the end.
Experiment also a Tweak() at the end instead at the beginning.
And check the levels with an Histogram after the processing. They should be now 0-255 (because QTGMC). Experiment if moving them back to 16-235 improves or not the display on your SmartTV
Not sure that the colors parameters are necessary in your ffmpeg command line, otherwise ok
London (04-18-2022),
msgohan (04-19-2022)
04-18-2022, 01:55 PM
I cannot call Ylevels (I am using AviSynth+ if that matters). I downloaded Ylevels from the AviSynth External Filters page, placed the file as Ylevels.avsi into the plugins+ and plugins64+ directories, but AviSynth+ displays an error.
Also, Lollo I don't know how to run your scripts and LevelsLumaOnly mentioned in post#9. Can you guide me on how to install those please.
At the end of my script I had used ConvertToYUY2(interlaced=false) because earlier I had used TemporalDegrain2 and LSFmod which required a conversion to YV12 from my YUY2 source. I included (interlaced=false) because QTGMC would have deinterlaced the file by this point.
I have Histogram("classic") orientated horizontally and positioned above the video. It would be usfeul if I could display at the same time the Histogram("classic") to the right. I tried but failed with this:-
Crop(20,256,-20,-20).Histogram("levels")
I was trying to get Histogram("levels") to read only the video and not be affected by the Histogram("classic") running above the video.
Finally, I added those colour parameters to the ffmpeg line to ensure the video is tagged with the BT.609 in Media Info. If you know much about this then ideally I want to tag it as colour system "I" not "B/G". That is probably only a minor difference, but for accuracy it would be good to know if that is possible.
04-18-2022, 03:16 PM
your full script modified to include the functions:
\ c)
AssumeTFF()
Trim(30,42624)
LevelsLumaOnly(10, 1.0, 245, 16, 235, coring=false, dither=true)
Crop(14,0,-10,-12)
AddBorders(4,4,4,8)
Prefetch(14)
Add this function and call it with ClassicAndLevelsHistogram inside your script as per above
# Classic Histogram and Levels Histogram
function ClassicAndLevelsHistogram(clip video)
classic = video.TurnRight().Histogram().TurnLeft().crop(0,0,-0,256)
levels = video.Histogram("levels").crop(video.width,0,-0,256)
classic_and_levels = stackhorizontal(classic, levels) # stack classic and levels horizontally
video2 = video.addborders(0,0,classic_and_levels.width-video.width,0) # add a black border to side of the video to match the width of "both"
stackvertical(classic_and_levels, video2) # stack the analytics over the video
Remember to check the levels at the end!
04-18-2022, 05:25 PM
Thanks Lollo, it is really useful to see both the Classic and Levels Histograms simultaneously.
I had to add ConvertToYV12 just before calling ClassicAndLevelsHistogram(), but your script is working a treat.
I am not familiar with Functions in AviSynth......do Functions need to be placed at the beginning of the script, and then called where required? If I placed a function within the sequence of scripts it did not run when I called it. I will do some more reading on this. I have learned plenty over this weekend, thanks to your help!. Certainly I will be able to proceed with capturing more tapes in confidence with the settings I am making and now have a better understanding of how to carry out basic filtering correctly.
04-23-2022, 12:48 PM
Did some testing with my "VC500CXT" model on Win10 today.
Can confirm: - Histogram contains spikes at Default levels. For me, Contrast = 5928 seems to be the one and only magic number for a spike-free "Capture mode histogram"(*). This isn't really usable, even if it does "fix" the spikes: it's way too high to avoid clipping with normal tapes, even if I massively lower Brightness.
- After changing Video Standard in Capture Filter, Y<16 is clipped. (I was mainly testing changing from NTSC_M to NTSC_M_J and vice-versa.) An unplug/replug cycle resolves this, as noted by both London and Hodgey in the quotes at post bottom.
(*) I haven't confirmed how a capture with this setting measures in Avisynth.
Yes, its capture range is 14-245, OP should play on the procamp only when signals are outside that range.
Hmm. For me, it appears to be 1-254 with NTSC. (Again, haven't confirmed with actual measurement, just eyeballing the VDub display -- and I can't test PAL.)
London (04-23-2022)
04-23-2022, 03:30 PM
That's interesting the Contrast setting at 5928 eliminates the spikes in the capture Histogram. As the spikes don't seem to affect the captured file and are easily removed with simple filtering I leave Contrast, Saturation and Hue at default (4992), Sharpness at 0 and only adjust Brightness to centre the capture histogram.
I did 3 tests with the Brightness setting adjusted for lower, higher and then centralised levels in the capture histogram. Checking the captured files in AviSynth my VC500 is capturing from 0 to 254.
As a routine now, before temporary cropping and capture Histogram check, I always make sure the VC500 is not clipping at <16.
The following users thank London for this useful post:
msgohan (04-24-2022)
