06-03-2022, 07:52 AM
I have spent some time tweaking the FixRipsP2 script (based on Didée's script initially ) and i believe i've nailed it. It now remove effectively grains/noise and keeps lots of details without weird artifacts (like warping).
I have tweaked: the motion vectors parameters to my liking (probably the hardest part), removed Tmedian2 (which cause warping) replaced with a tweaked version of Spotless.
This script is very useful for vhs with: grains, noise, dropouts
Feel free to try it with your video and report how good (or bad) it is for further tweaks.
Note: tested on Live footage from a VHS
video_org=AVISource("MyVideo.avi")
# plugins directory
plugins_dir="C:\Program Files (x86)\AviSynth 2.6\plugins"
# FixRipsp2
Import(plugins_dir + "FixRipsP2_themaster1.avs")
### separate fields
video_org_sep=video_org.AssumeTFF().separateFields ()
### select even fields
video_org_sep_even=SelectEven(video_org_sep)
### select odd fields
video_org_sep_odd=SelectOdd(video_org_sep)
### repair
video_org_sep_even_rep=video_org_sep_even.FixRipsp 2()
video_org_sep_odd_rep=video_org_sep_odd.FixRipsp2( )
### interleave
video_interleaved=interleave(video_org_sep_even_re p,video_org_sep_odd_rep)
### weave
video_restored=video_interleaved.Weave()
last=video_restored
#return(video_restored)
File Type: jpg resto-fixrip_applied_on_fields-best.jpg (247.4 KB, 41 downloads)
The following users thank themaster1 for this useful post: lollo2 (06-03-2022), The_Outsider (06-11-2022)
06-03-2022, 08:17 AM
lollo2 lollo2 is offline
Thanks a lot themaster1!
06-11-2022, 07:31 AM
Selur Selur is offline
@master1: Got a question you might be able to answer.
I wanted to combine your script with support for svp from https://forum.doom9.org/showthread.php?p=1574161
using:
#### TWEAKED VERSION OF FIXRIPSP2 , BY THEMASTER1, June 2022
# TO REMOVE GRAINS, DROPOUTS (Only light ones, not multi frames ones)
# http://www.digitalfaq.com/forum/video-restore/12806-fixrips-grainnoisedropouts-script.html
# The original script comes from Didée, see more here: http://forum.doom9.org/showpost.php?p=1483709&postcount=10
# + svp from https://forum.doom9.org/showthread.php?p=1574161, note that blocksize is only 8 not for as when using mvtools
function FixRipsP2(clip a,  bool "svp")
    svp=default(svp,false)
    a
    clense(reduceflicker=false).merge(last,0.5).clense(reduceflicker=false)
    mot=removegrain(8,0).DepanEstimate(range=2)
    take2=a.depaninterleave(mot,prev=2,next=2,subpixel=2)
    clean1=take2.selectevery(5,2)
    clean1=clean1.mt_lutxy(clean1,"x 1 + y < x 2 + x 1 - y > x 2 - y ? ?",U=2,V=2)
    svp ? { # using svp
        sup1 = clean1 .SVSuper("pel:2, scale:{up:0}")
        search_params="block:{w:4,overlap:2}" # can't use blocksize 4, w:4 <> blocksize 8
        v21=sup1.SVAnalyse("{"+search_params+"}")
        v22=sup1.SVAnalyse("{"+search_params+",special:{delta:2}}")
        bv22=v22.SVConvert(isb=true)
        bv21=v21.SVConvert(isb=true)
        fv21=v21.SVConvert(isb=false)
        fv22=v22.SVConvert(isb=false)
        sup2 = a.msuper(pel=2,levels=1,sharp=2)
        interleave(a.mcompensate(sup2,fv22),a.mcompensate(sup2,fv21),a,a.mcompensate(sup2,bv21),a.mcompensate(sup2,bv22))
        selectevery(5,2)
        sup3 = last.msuper(pel=2,sharp=2,hpad=0,vpad=0)
        # SVAnalyse accepts MSuper with zero padding!
        v31=sup3.SVAnalyse("{"+search_params+"}")
        v32=sup3.SVAnalyse("{"+search_params+",special:{delta:2}}")
        v33=sup3.SVAnalyse("{"+search_params+",special:{delta:3}}")
        bv33=v33.SVConvert(isb=true)
        bv32=v32.SVConvert(isb=true)
        bv31=v31.SVConvert(isb=true)
        fv31=v31.SVConvert(isb=false)
        fv32=v32.SVConvert(isb=false)
        fv33=v33.SVConvert(isb=false)
    } : { # using mvtools
        sup1 = clean1.msuper(pel=2,sharp=0)
        bv21=sup1.manalyse(isb=true, truemotion=true,global=true,delta=1,blksize=4,overlap=2,search=3,searchparam=5,DCT=2)
        bv22=sup1.manalyse(isb=true, truemotion=true,global=true,delta=2,blksize=4,overlap=2,search=3,searchparam=5,DCT=2)
        fv21=sup1.manalyse(isb=false,truemotion=true,global=true,delta=1,blksize=4,overlap=2,search=3,searchparam=5,DCT=2)
        fv22=sup1.manalyse(isb=false,truemotion=true,global=true,delta=2,blksize=4,overlap=2,search=3,searchparam=5,DCT=2)
        #SpotLess(RadT=5,ThSAD=1000000,ThSAD2=1000000,pel=2,chroma=false,BlkSz=8,Olap=4,tm=false,glob=false,bBlur=0.0).selectevery(5,2) # proposed by The Filter  Developper
        SpotLess(RadT=2,ThSAD=500000,ThSAD2=499000,pel=2,chroma=true,BlkSz=4,Olap=2,tm=false,glob=false,bBlur=0.0).selectevery(5,2) # to remove less  fine details BlkSz=4,Olap=2 et RADT=1 (If higher it creates artifacts)
        sup3 = last.msuper(pel=2,sharp=2)
        bv31=sup3.manalyse(isb=true, truemotion=true,global=true,delta=1,blksize=4,overlap=2,search=3,searchparam=5,DCT=2)
        bv32=sup3.manalyse(isb=true, truemotion=true,global=true,delta=2,blksize=4,overlap=2,search=3,searchparam=5,DCT=2)
        bv33=sup3.manalyse(isb=true, truemotion=true,global=true,delta=3,blksize=4,overlap=2,search=3,searchparam=5,DCT=2)
        fv31=sup3.manalyse(isb=false,truemotion=true,global=true,delta=1,blksize=4,overlap=2,search=3,searchparam=5,DCT=2)
        fv32=sup3.manalyse(isb=false,truemotion=true,global=true,delta=2,blksize=4,overlap=2,search=3,searchparam=5,DCT=2)
        fv33=sup3.manalyse(isb=false,truemotion=true,global=true,delta=3,blksize=4,overlap=2,search=3,searchparam=5,DCT=2)
    #last.mdegrain1(sup3,bv31,fv31,bv32,fv32,bv33,fv33,thSAD=499)
    last.mdegrain1(sup3,bv31,fv31,thSAD=499)
    #last.mdegrain1(sup3,bv31,fv31,thSAD=499)
    interleave()
    return last
function MinBlur(clip clp, int r, int "uv")
    uv   = default(uv,3)
    uv2  = (uv==2) ? 1 : uv
    rg4  = (uv==3) ? 4 : -1
    rg11 = (uv==3) ? 11 : -1
    rg20 = (uv==3) ? 20 : -1
    medf = (uv==3) ? 1 : -200
    RG11D = (r==0) ? mt_makediff(clp,clp.sbr(),U=uv2,V=uv2)
     \    : (r==1) ? mt_makediff(clp,clp.removegrain(11,rg11),U=uv2,V=uv2)
     \    : (r==2) ? mt_makediff(clp,clp.removegrain(11,rg11).removegrain(20,rg20),U=uv2,V=uv2)
     \    :          mt_makediff(clp,clp.removegrain(11,rg11).removegrain(20,rg20).removegrain(20,rg20),U=uv2,V=uv2)
    RG4D  = (r<=1) ? mt_makediff(clp,clp.removegrain(4,rg4),U=uv2,V=uv2)
     \    : (r==2) ? mt_makediff(clp,clp.medianblur(2,2*medf,2*medf),U=uv2,V=uv2)
     \    :          mt_makediff(clp,clp.medianblur(3,3*medf,3*medf),U=uv2,V=uv2)
    DD    = mt_lutxy(RG11D,RG4D,"x 128 - y 128 - * 0 < 128 x 128 - abs y 128 - abs < x y ? ?",U=uv2,V=uv2)
    clp.mt_makediff(DD,U=uv,V=uv)
    return(last)
function SpotLess(clip c,int "RadT",int "ThSAD",int "ThSAD2",int "pel",bool "chroma", int "BlkSz",Int "Olap",bool "tm",Bool "glob",Float "bBlur") {
    RadT = Default(RadT,1) # Temporal radius. (MCompensate arg)
    ThSAD = Default(ThSAD,10000) # SAD threshold at radius 1 (Default Nearly OFF).
    ThSAD2 = Default(ThSAD2,ThSAD) # SAD threshold at radius RadT.
    Pel = Default(pel,2) # Default 2. 1, 2, or 4. Maybe set 1 for HD+. (1=precision to pixel, 2=precision to half pixel, 4=quarter pixel)
    Chroma = Default(chroma,True) # MAnalyse chroma arg. If set to true, use chroma in block matching.
    BlkSz = Default(BlkSz,8) # Default 8. MAnalyse BlkSize. Bigger blksz quicker and perhaps better, esp for HD clips. Maybe also better where BIG noise.
    OLap = Default(OLap, BlkSz/2) # Default half of BlkSz.
    Tm = Default(tm,True) # TrueMotion, Some folk swear MAnalyse(truemotion=false) is better.
    Glob = Default(glob,Tm) # Default Tm, Allow set MAnalyse(global) independently of TrueMotion.
    Bblur = Default(bblur,0.0) # Default OFF
    Assert(1 <= RadT,"SpotLess: 1 <= RadT")
    pad = max(BlkSz,8)
    sup = (bBlur<=0.0 ? c : c.blur(bblur)).MSuper(hpad=pad,vpad=pad,pel=pel,sharp=2)
    sup_rend = (bBlur<=0.0) ? sup : c.MSuper(hpad=pad,vpad=pad,pel=pel,sharp=2,levels=1) # Only 1 Level required where not MAnalyse-ing.
    MultiVec = sup.MAnalyse(multi=true, delta=RadT,blksize=BlkSz,overlap=OLap,search=4,chroma=Chroma,truemotion=Tm,global=Glob)
    c.MCompensate(sup_rend,MultiVec,tr=RadT,thSad=ThSAD,thSad2=ThSAD2)
    MedianBlurTemporal(radiusY=0,radiusU=0,radiusV=0,temporalradius=RadT) # Temporal median blur only [not spatial]
    SelectEvery(RadT*2+1,RadT) # Return middle frame
Problem is the syntax of the ?-operator seems to be wrong.
I thought I correctly looked it up over at http://avisynth.nl/index.php/Block_statements, but that does not seem to be the case.
Do you see the what I did wrong?
Cu Selur
06-11-2022, 03:22 PM
Jeez.. i wish, I'm not a coder by any means, just a sub-par tweaker lol. I'm sure they'll help you out on doom9, brilliants minds over there. I support this SVP tweak though (MV's calculated by GPU) , anything to speed up the processing of this script is welcome.
06-12-2022, 01:39 AM
okay, will probably figure it out later today.
06-12-2022, 05:55 AM
What I don't understand in your script, you use:
  1. Code:
    and not
    last.mdegrain3(sup3,bv31,fv31,bv32,fv32,bv33,fv33,thSAD=499)
  2. when you use mdegrain1, why are you still spending tons of time computing:
    and
without those your main function is just:
function FixRipsP2(clip a)
    a
    sup1 = clean1
     \           .mt_lutxy(clean1,"x 1 + y < x 2 + x 1 - y > x 2 - y ? ?",U=2,V=2)
     \           .msuper(pel=2,sharp=0)
    interleave()
    return last
Cu Selur
06-12-2022, 06:30 AM
What seems strange is that you only replaced TMeadian2 with Spotless in one occurance and simpls dropped the other.
You only use it for sup3, but Didée used it for all sups. This seems strange.
06-12-2022, 03:58 PM
One instance of spotless is enough to me (tested many times) and i prefer removegrain1 (some grain removed and details are well preserved)
You're right by the way, you could remove the bv32 bv33 / fv32 fv33 lines (mdegrain1 = 1 frame radius, mdegrain2 = 2 frames etc..)
06-15-2022, 03:56 PM
Here's a port of your version using SVP in the FixRipsP2 part:
function FixRipsP2SVP(clip "a", bool "twofold")
    a
    Clense(reduceflicker=false).Merge(last,0.5).Clense(reduceflicker=false)
    mot=RemoveGrain(8,0).DepanEstimate(range=2)
    take2=a.DePanInterleave(mot,prev=2,next=2,subpixel=2)
    clean1=take2.SelectEvery(5,2)
    search_params="gpu: 1, block:{w:4,overlap: 2}" # can't use blocksize 4, w:4 <> blocksize 8
    sup1 = clean1.mt_lutxy(clean1,"x 1 + y < x 2 + x 1 - y > x 2 - y ? ?",U=2,V=2)
    sup1 = sup1.SVSuper("{ pel: 2, gpu: 1, scale: { up: 0 } }")
    v22=sup1.SVAnalyse("{"+search_params+", special: { delta: 2 } }")
    sup2 = a.MSuper(pel=2,levels=1,sharp=2)
    src = interleave(a.MCompensate(sup2,fv22),a.MCompensate(sup2,fv21),a,a.MCompensate(sup2,bv21),a.MCompensate(sup2,bv22))
    src = src.SpotLess(RadT=2,ThSAD=500000,ThSAD2=499000,pel=2,chroma=true,BlkSz=4,Olap=2,tm=false,glob=false,bBlur=0.0) # to remove less  fine details BlkSz=4,Olap=2 et RADT=1 (If higher it creates artifacts)
    src = src.SelectEvery(5,2)
    sup3 = src.SVSuper("{ pel: 2, gpu: 1, scale: { up: 0 } }")
    search_params="gpu: 1, block:{w:4,overlap:2}}" # can't use blocksize 4, w:4 <> blocksize 8
    sup3 = src.MSuper(pel=2,sharp=2)
    last.MDegrain1(sup3,bv31,fv31,thSAD=499)
    return interleave()
    uv   = default(uv,3)
     \    : (r==1) ? mt_makediff(clp,clp.RemoveGrain(11,rg11),U=uv2,V=uv2)
     \    : (r==2) ? mt_makediff(clp,clp.RemoveGrain(11,rg11).RemoveGrain(20,rg20),U=uv2,V=uv2)
     \    :          mt_makediff(clp,clp.RemoveGrain(11,rg11).RemoveGrain(20,rg20).RemoveGrain(20,rg20),U=uv2,V=uv2)
    RG4D  = (r<=1) ? mt_makediff(clp,clp.RemoveGrain(4,rg4),U=uv2,V=uv2)
     \    : (r==2) ? mt_makediff(clp,clp.MedianBlur(2,2*medf,2*medf),U=uv2,V=uv2)
     \    :          mt_makediff(clp,clp.MedianBlur(3,3*medf,3*medf),U=uv2,V=uv2)
    return(last)
Function SpotLess(clip c,int "RadT",int "ThSAD",int "ThSAD2",int "pel",bool "chroma", int "BlkSz",Int "Olap",bool "tm",Bool "glob",Float "bBlur") {
    pad = max(BlkSz,8)
should be faster but might blur more since it one can use blocksize 8 not 4.
Cu Selur
The following users thank Selur for this useful post: lollo2 (06-15-2022)
06-16-2022, 01:04 AM
Hey well done, could be useful for animes perhaps (not my area).
Though, Svp is not exactly "motion safe" i've noticed it before when messing with motion interpolation
In any case i couldn't have done it better
06-16-2022, 01:29 AM
Happy if someone has any usage for it. I'm usually not really using AviSynth so I won't use it.
I gues the motion problem is related to the bloack size ony be 8.
Cu Selur
Panasonic S-VHS player grain noise? pthebest19 Video Hardware Repair 41 06-26-2022 07:26 PM
De-grain filter for this video? latreche34 Encode, Convert for discs 2 04-20-2020 01:40 PM
Cartoon restoration project - film grain noise removal? via Email or PM Restore, Filter, Improve Quality 1 07-26-2014 11:39 AM
Can't remove video noise/artifacting (grain in dark areas?)) DeeSeven Restore, Filter, Improve Quality 8 07-23-2014 08:19 AM
Help restoring dot crawl, dropouts, and grain on VHS videos? zack82 Restore, Filter, Improve Quality 18 04-29-2014 08:35 PM
