06-30-2022, 04:41 PM
BruceOlsen BruceOlsen is offline
I'm starting to figure out the corrections I need to make on most caps but I don't have any idea what to do with this 2nd gen VHS copy
I'm not too worried about the shaking, it's everything else.
Thanks.
07-01-2022, 05:11 AM
lollo2 lollo2 is offline
Apart from some color correction to remove the green cast and some stabilization there is not much you can improve. No details neither colors are present.
Some restoration example with color correction from sanlyn:
http://www.digitalfaq.com/forum/vide...bunch-vhs.html
http://www.digitalfaq.com/forum/vide...-vertical.html
Searching the forum you can find more.
07-01-2022, 02:12 PM
traal traal is offline
The blacks are crushed, luma needs to be adjusted before capture:
Video8 transfer quality problems? theodore1 Capture, Record, Transfer 12 04-20-2019 10:04 AM
Problems with Windows XP SP3 capture, soundcard problems? Prelude Capture, Record, Transfer 13 02-20-2015 02:23 PM
Quality problems on damaged CD and DVD? gamemaniaco Blank Media 81 03-20-2014 10:09 AM
Problems with Ritek DVD-R quality, archived article (2004) lordsmurf Blank Media 2 11-11-2010 04:01 AM
Splitting across multiple DVD’s fidel1962 Copy DVDs, Duplicate, Replicate 1 07-18-2005 05:31 AM
