07-30-2022, 10:06 AM
crissrudd4554 crissrudd4554 is offline
Hello, I recently got my hands on a JVC DR-M10 DVD Recorder. It seems to be functioning however it wont use any of my blank discs. I tried DVD-RW's and it says "Could Not Format The Disc Check The Disc". I switched to a DVD-R. It says "Reading" and then clears out. No message about Formatting or anything. I then push record and it tells me the disc is not recordable. Any tips on this???
After looking into this a little bit it appears my DVD-R’s are at a speed of 16x which the recorder doesn’t support and only supports DVD-RWs with speed of 2x. While this may answer the question as to why the DVD-Rs aren’t working (assuming I’m reading into this correctly), it doesn’t exactly answer why my DVD-RW’s don’t work since the discs labels them as 4x/2x.
NEVERMIND. The person who sold me the unit provided a recordable disc compatible with the unit. I’m recording as we speak!
07-30-2022, 02:01 PM
Quality 16x DVD-R media is fine.
Random 16x media will not work well, or at all.
2x -RW media only
Not +RW
Not 4x -RW, or faster.
07-30-2022, 04:57 PM
Which would be consider quality 16x??
08-01-2022, 07:23 AM
Verbatim AZO, MCC code/ID, and the discs are actually 1x-16x, not just 16x. I have this recorder, I use those discs (and others, but these easiest to get).
The following users thank lordsmurf for this useful post: crissrudd4554 (08-01-2022)
Best blank DVDs in 2020? kschwi Blank Media 7 05-30-2020 01:19 AM
Blu-ray blank DVDs to get full quality? Superstar Blank Media 5 08-25-2015 03:01 PM
Which blank DVDs should I buy for archival quality ? ccjjff2 Blank Media 14 08-02-2012 11:35 AM
What are the best blank DVDs? Where should I buy them? [REVIEW] admin Blank Media 0 12-16-2010 03:48 PM
Blank dvds d.smyth Blank Media 1 09-18-2006 06:00 AM
