09-28-2022, 05:36 AM
scyllx scyllx is offline
Hello!
If yall know FiveM the app for GTA 5 that you can play in some servers, so before like 2,3 years ago i was making drift videos and record them with rockstar editor then export them at 25% speed not like the original speed was 100%, so i used 25% or 35% speed so the video to be slow, and then i did something like before a friend showed me how it was done but i want to come back with the vids and i want to have those smooth videos, so when i put the slowed video rendered from rockstar editor, then i go to Video-Frame Rate and i select the second one and i type 300fps then i go to compression and i put the Lagarith Codec, and then export it but the video aint smooth + its fast asf.. and i cant remember how i did it, should look like this https://www.youtube.com/watch?v=-Dtfp5ooUwE this video is mine but old one. If someon knows how to make it like that i will be thankful <3
VirtualDub allows only 25fps in video capture? adamstefan Capture, Record, Transfer 3 11-05-2022 06:44 PM
Toshiba RDXS35 - CompactFlash works as a HDD, copy to PC is smooth jwillis84 Capture, Record, Transfer 0 03-31-2019 03:18 AM
Getting no video with VirtualDub 64-bit? GWEBB47 Capture, Record, Transfer 1 02-12-2018 05:49 AM
VirtualDub - Can't Capture Video rckowal Capture, Record, Transfer 7 01-19-2010 06:49 PM
The magic of Photoshop - Making models have smooth skin lordsmurf Photo Processing, Scanning & Printing 8 04-15-2006 10:19 AM
