09-15-2023, 06:33 PM
Townly Townly is offline
I picked up a Panasonic DMR-ES10 and bought a remote separately (N2QAKB000055). The remote powers the ES10 on and I can also use the Input Select on the remote to set the ES10 input. However, I can't get into any menus (functions, display, setup etc) on the remote don't do anything on the ES10...do I need to plug it into a TV to see the menus? Or program the remote etc?
09-17-2023, 06:06 AM
There's nothing to program.
The remote is probably just broken. In some settings, remotes were consumables, wore out in time.
I can confirm that is a model that should work with both ES10 and ES15.
09-22-2023, 09:59 AM
So I just bought another remote and the same result...remote powered the ES10 on, and I can change inputs, open/close disk drive but nothing happens when I press "setup, functions, sub-menu etc". Any other ideas to try? Thanks!
09-22-2023, 01:32 PM
Well I just connected it to a monitor as well (probably should have done that first) and looks like there's no picture either. May have just purchased a dud...bummer. Seller said it was working but I have yet to have that same luck.
es10, panasonic, pass thru, remote
Panasonic DMR-ES10 remote model? koberulz Video Hardware Repair 31 03-13-2026 10:59 PM
For trade: Panasonic DMR-ES10 (EU) for Panasonic DMR-ES25 (US) marukuru Marketplace 3 07-08-2021 01:20 PM
Panasonic ES10 remote control sensor failure? cbehr91 Video Hardware Repair 1 04-12-2021 08:50 PM
Which remote for Panasonic VCR? monks19 Videography: Cameras, TVs and Players 1 01-01-2013 10:54 PM
