11-20-2023, 08:29 PM
HomeVideoProject HomeVideoProject is offline
I'm capturing about 100 MiniDV tapes to AVI and I have a basic question for long term storage.
While I plan to keep the AVI files on my NAS and cloud backup, I'm also looking for a way to share the contents with some elder family members for their ease of viewing.
I noticed the AVI files are captured at an overall constant bitrate of 29.8 Mb/s. My understanding is that the Blu-ray SD MPEG-2 max bitrate is 15 Mb/s.
Based on this, is it factual that burning these files onto a Blu-ray as data would retain closer to original quality than encoding it to be played like a Blu-ray video? And if so, should most modern Blu-ray players be able to play AVIs burned onto Blu-ray discs?
11-21-2023, 12:00 AM
DV should constant bitrate of 25Mbps, Anything else is indicating something gone wrong with the transfer or the player is not reading the real bitrate.
If there is a possible way of playing back the files as they are do so, if not you can de-interlace, resize to 1440x1080 and encode to h.264 square pixel and share over internet or flash media. Much easier than authoring onto a Blu-ray.
11-21-2023, 08:12 AM
You're right, I was looking at the Overall Bitrate vs. just the Video Bitrate (details below).
So just to clarify, you're saying putting it into a h.264 MKV and then burn as data on a blu-ray would give a better probability of it working on their blu-ray players than the raw AVI?
General
Complete name : L:\DV Transfer\Adobe Premiere Pro Captured Video\Untitled114\Untitled Clip 08.avi
Format : AVI
Format/Info : Audio Video Interleave
Commercial name : DVCPRO
Format profile : OpenDML
Format settings : BitmapInfoHeader / WaveFormatEx
File size : 12.3 GiB
Duration : 58 min 59 s
Overall bit rate mode : Constant
Overall bit rate : 29.8 Mb/s
Frame rate : 29.970 FPS
Recorded date : 2003-06-30 09:28:29.000
Video
Format : DV
Codec ID : dvsd
Codec ID/Hint : Sony
Bit rate mode : Constant
Bit rate : 24.4 Mb/s
Width : 720 pixels
Height : 480 pixels
Display aspect ratio : 4:3
Frame rate mode : Constant
Frame rate : 29.970 (30000/1001) FPS
Original frame rate : 29.970 (29970/1000) FPS
Standard : NTSC
Color space : YUV
Chroma subsampling : 4:1:1
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Bottom Field First
Compression mode : Lossy
Bits/(Pixel*Frame) : 2.357
Time code of first frame : 00:00:00;17
Time code source : Subcode time code
Stream size : 11.9 GiB (97%)
Encoding settings : ae mode=full automatic / wb mode=automatic / white balance= / fcm=manual focus
Audio
Format : PCM
Format settings : Little / Signed
Codec ID : 1
Bit rate : 1 024 kb/s
Channel(s) : 2 channels
Sampling rate : 32.0 kHz
Bit depth : 16 bits
Stream size : 432 MiB (3%)
Alignment : Aligned on interleaves
Interleave, duration : 967 ms (28.99 video frames)
11-21-2023, 11:58 AM
No, I said share over internet or flash media.
11-21-2023, 08:32 PM
traal traal is offline
Yes, H.264 will likely be more compatible with Blu-ray players than DV.
But also, .MP4 will likely be more compatible than .MKV.
I wish it were easier to author a video Blu-ray.
Properly cropped video, what to encode to? drzapp Edit Video, Audio 4 12-09-2018 08:03 PM
Can I just burn my large .WMV file to disc as data? momnewbie Encode, Convert for discs 5 10-12-2015 11:39 AM
Where is audio/video sync data located in video files? merchantord Edit Video, Audio 5 07-26-2014 11:52 PM
Long time to burn and extract DVD data disc gamemaniaco Blank Media 27 10-15-2013 06:58 AM
Encode or re-encode, one progran as good as another? cyber-junkie Encode, Convert for discs 1 08-13-2010 05:05 PM
