02-01-2024, 04:18 PM
Scoot Meevo Scoot Meevo is offline
Hi
Looking to digitise some VHS tapes. Have a Panasonic NV-FS100 VHS player and was hoping to buy one of the Panasonic DVD recorders for a bit of extra picture stability without spending much. (Can't afford a £400 VHS player now, because I've just had to get a new roof...)
Unfortunately, after two attempts with separate Es-15 machines, I've encountered the same problem with both - that is, they make the picture worse rather than better. Both add much more waves and ripples than just the original VHS picture.
Will this be the known capacitor issues or could there be another reason? (I know how to solder, but my iron is 30 years old and seems to lack the heat for good joints nowadays)
I'm in Scotland, so dealing with the European PAL versions of the DVD recorders
Panasonic ES10 and ES15 the same for passthrough? colony Capture, Record, Transfer 16 10-03-2022 02:38 PM
Panasonic DMR ES10 passthrough setup? qiko Capture, Record, Transfer 8 04-05-2022 02:06 PM
Panasonic DMR-ES15 Passthrough for JVC DR-M10? ddw_119 Capture, Record, Transfer 6 11-04-2021 09:59 PM
Panasonic DMR-E55EG like ES10 passthrough? Uraz88 Capture, Record, Transfer 7 03-24-2021 07:29 PM
Using Panasonic ES10 DVD as a Passthrough RABinMS Restore, Filter, Improve Quality 7 07-20-2014 06:50 AM
