07-23-2010, 01:31 PM
lyrxtig lyrxtig is offline
In the Thread "Canopus ADVC300 vs Matrox G400TV - DV vs HuffYUV" Lordsmurf mentioned that
"The Matrox Marvel G400-TV card is an MJPEG hardware card, but I'll assume you've found a way around the hardware compression, bypassing it for lossless or uncompressed AVI capture. (Bypass is common on a lot of hardware encoders, such as Hauppauge or ATI MPEG encoders.)
What is this bypassing he is talking about for the Matrox Marvel G400-TV card and where can I find a guide to do it?
Also is it better to capture home videos using uncompressed AVI with the Matrox Marvel G400-TV card or DV with the Canopus ADVC100?
07-24-2010, 02:01 PM
I think the other person in that thread had mentioned the bypass, not lordsmurf. He was only referring to the action taken by the other poster.
Generally speaking, if you can see the capture card in VirtualDub, you're able to capture AVI files, which means you're able to use an installed system encoding codec. HuffYUV, for example, or even the newly-available Matrox codecs (broadcast MPEG-2, Matrox DV, etc).
I would always opt for uncompressed or lossless (HuffYUV) encoding, when possible. Next choice is high bitrate MPEG-2. I put DV dead last, of the 3 choices. The colorspace compression is just not conducive to quality VHS/8mm conversions. (That would include S-VHS, Hi8, etc)
The ADVC100 is also not the best of devices, nor is their DV codec the best one. I'd much prefer to use a Canon camera in pass-through mode, given the choice of DV methods. Or Matrox DV, with any number of devices (now near-limitless, since Matrox made their DV codecs available a few months ago).
If you search the forum, you'll find past posts on DV compression, Matrox codecs, and VirtualDub capturing.
Hope that helps!
Enhance uncompressed 320x240 digital video admin Restore, Filter, Improve Quality 24 03-20-2011 02:56 AM
OK got hardware now what? rlschoemer Capture, Record, Transfer 3 11-19-2009 08:14 AM
MJPEG options and alternatives? lordsmurf Capture, Record, Transfer 3 10-04-2009 09:16 AM
What having the right hardware could do for you markatisu Restore, Filter, Improve Quality 3 09-08-2005 08:53 AM
Understanding hardware strangepork Computers 1 10-19-2004 05:42 AM
