04-10-2011, 07:29 AM
videoviking videoviking is offline
Send a message via MSN to videoviking Send a message via Skype™ to videoviking
Thanks to lordsmurf and kpmedia for useful advice.
After having recorded a lot of video on my Sony HDR XR500, the time has come to try and put together some of the stuff. The camera makes one .mts-file for each scene shot. If I look at the video with the camera connected to the TV, the picture is smooth and nice.
However, after trying to edit the video in Premiere CS4, I have problems with the quality. I can get good picture quality but the movements are much more "jerky" than when I view it from the camera.
I want to keep the final video on the harddisk of my HTPC for viewing on the connected TV and also later be able to make DVDs from it.
Any suggestion on format/codec?
Is it possible to edit and store in the same .mts file type?
04-12-2011, 09:56 AM
Since this is a new topic, I've moved it to its own post.
That sounds like either a framerate change, or a drop-field deinterlace. I'd look to the framerate first. What fps is the camera shooting? And then does it match the project settings in Premiere? It's easy to make this mistake, even I've done it.
Not with Premiere, no. "MTS" or "M2TS" is an MPEG broadcast transport stream wrapper, which is also used in quite a few cameras. I don't shoot a lot of video, so I don't recall all of the specific formats that can be held within the wrapper. Obviously MPEG-2 is there, but I believe MPEG-4 is also allowed, which opens the door for formats like H.264. You'd need to do a Gspot or Mediainfo on the file, to learn what the source really is.
Premiere can output quite a few formats, but given that it's being decoded/re-encoded, I don't much see the point in putting it back to a .mts file. You could just as easily encode it to a more standardized MPEG-2 in an .mpg file (used for DVD). Or even output as H.264 in an MP4 file (used for Blu-ray or streaming videos).
If you're just removing unwanted footage, and don't want to re-encode the video, there are other editors like Womble and VideoReDo that you may want to try. Those would run about $100, so it depends on what you want to spend. For adding any sort of effects, or doing anything aside from cutting out unwanted footage, Premiere is one of the best tools for editing video.
Adobe Premiere Elements or Adobe Premiere Pro?
And which version number?
Recommendations to transfer video from capture PC to main PC? GroverXpup Project Planning, Workflows 3 11-24-2017 05:13 PM
Format problem MagnificentMarcus Encode, Convert for discs 7 08-24-2006 08:10 AM
