07-25-2005, 06:40 PM
MagnificentMarcus MagnificentMarcus is offline
Can someone point me to instructions on how to record a radio program, convert it tp audio files and then convert it to a CD?
07-25-2005, 07:14 PM
markatisu markatisu is offline
I think you need one of those USB FM Tuners, my friend has XM Satellite and just pumps it in through the audio in and uses a recording program (there are a ton, some free) and then it records it as wav and then he just puts that to a CD or compresses it into 256k MP3 and makes a MP3 Data disc
But I think you do need some sort of antenna otherwise your option is streaming radio which I think has a lower bitrate
07-28-2005, 02:45 AM
funky-rat funky-rat is offline
If you can get it on streaming audio (ie: internet radio) there are numerous ripping programs out there. Really simple to burn to cd after that....
07-28-2005, 03:49 AM
I can get the show by streaming audio, but the problem is that in the place of commercials it has goofy music which is a little annoying. I do know that you can record it on to a tape, but I'm not sure how you could convert the tape to a CD. Do you have to get a special machine or an adapter to hook to your computer?
07-28-2005, 04:19 AM
joker joker is offline
If you want to capture (save) streaming audio/video look for Net Transport.
I use it all the time, works great.
Dvd copying program gatch72 Copy DVDs, Duplicate, Replicate 4 04-24-2007 01:38 AM
Looking for program...... scanning comics MOTUfan Project Planning, Workflows 3 01-15-2006 02:29 PM
DVD Program to make slideshows of pics with background music gatch72 Author, Make Menus, Slideshows, Burn 5 01-13-2006 01:28 AM
New LiteOn 5104 at Radio Shack lordsmurf Capture, Record, Transfer 7 08-18-2005 12:13 PM
Need a program to convert .vob to mpeg. Swingbelly Encode, Convert for discs 3 07-20-2005 04:41 PM
