03-29-2014, 09:12 PM
rappy rappy is offline
Ok. So things are going great with my captures. I have a tape that is a little crumpled and keeps getting caught up in the jvc 99000u. So I take a new case and switch out the reel in the new case. As I was doing this I was capturing a good tape with no problems. I put in the "fixed tape" so see if my handy work.....we'll worked. The tape didn't get caught, but it doesn't play right. It's basically a black screen, with a bunch of "noise". Not like the black and white snow noise, but rather a very dark screen. But when I fast forward the image plays correctly! I thought it was something wrong with the repaired tape, but I put in the other tape that until a few minutes ago played just fine.....and just my luck, it's doing the same thing!!!
What did I do????
EDIT:
Got a little scare there. Tapes seem to be playing fine now. Not sure why though?. I hope it doesn't happen again. For safe measure, I cleaned the video head with a little (91%) alcohol and a piece of paper (based on threads I read here). I do have a question regarding cleaning, but I will ask on the general forum.
03-30-2014, 01:11 PM
yes that sound like the crumpled tape may have shed some oxide onto the head.
avoid playing crumpled tape if you can and if you must clean after wards
i prefer chamois to paper as well
The following users thank volksjager for this useful post: lordsmurf (07-23-2014)
07-23-2014, 05:10 AM
Did you see anything on the cleaning swab?
- If so, volksjager is right. It's a good guess.
- If not, something else is at fault. And we'd need to still keep guessing.
But given all the data, it does sound like the most likely reasoning to me as well.
08-06-2014, 09:11 PM
Have not had any issues since! Knock on wood
MiniDV Tapes not playing - blank blue screen? naripeddi Videography: Cameras, TVs and Players 4 03-05-2013 10:37 PM
My Betamax video tapes go blank while playing? Nayls Capture, Record, Transfer 2 02-08-2013 08:54 AM
JVC HR-S7500EK PAL model any good for playing tapes? Zerowalker Capture, Record, Transfer 24 07-19-2012 07:02 AM
PAL videotape to DVD transfer problem lordsmurf Restore, Filter, Improve Quality 0 08-23-2010 03:04 AM
Do you need the remote to correctly work the Panasonic AG-1980 cyber-junkie Project Planning, Workflows 9 02-19-2010 11:46 AM
