12-05-2014, 09:11 PM
jriker1 jriker1 is offline
I have been using Virtualdub for a couple weeks to import VHS tapes into my PC with an ATI 600 USB device. Some were fine, some had Frames dropped, and some had Frames inserted, and some had both. I had a tape that had just Frames Inserted. About 26 of them. Happened twice. Here's the challenge. I cleaned off my hard drive, and set "No Display" on the video tab. The tape went thru without any Frames Inserted this time. Does turning off the display disable VirtualDub's process for Frames inserted and dropped frame detection? Or was the cleaning and defragging of the hard drive and possibly turning off the preview window just beneficial in the import process?
Thanks.
JR
12-06-2014, 06:20 AM
I figured it would come down to looking over the Virtualdub settings. I forget, but aren't you using a laptop (I wouldn't wish that on anyone) or the same hard drive as your OS (ditto)? Yes, defrag helps, turning off internet network connection (just unplugging doesn't help, the system still keeps searching for a connection), and all that. Turning off Preview is also a big step -- it seems to be designed for "preview", i.e, adjusting and whatnot rather than actual capture -- I've crashed VDub several times trying to capture and forgetting to turn Preview off on my older 1.8GHz capture PC.
12-06-2014, 08:58 AM
Thanks for the reply sanlyn. No, not a laptop. Using an old Dell desktop. 3GHz dual core. 6GB Ram but that's pointless because I'm on WinXP 32-bit.
  • With encoding using Lagarith Codec.
  • Network was right clicked and disabled
My Capture Timings:
My Disk I/O settings are:
Let me know if you need anything else to look at. Most/all should be set to what you recommended before. I know Disk I/O you mentioned to leave at default. Is Disable Windows write buffering a good thing?
For reference, CPU jumps between 6 and 35 percent so probably not an issue there.
Thanks.
JR
02-19-2015, 09:45 AM
Are you using an external TBC?
Hmm.... interesting.
It might. Because the graphics overlay/preview should not affect the capturing.
This is far more likely. When troubleshooting, only do one thing at a time. Otherwise, you'll not know what fixed it.
What are chances an external frame synchronizer tbc improves a signal with no dropped or inserted frames in vdub? quad4k Capture, Record, Transfer 0 07-23-2013 11:23 PM
Virtualdub with audio preview dropping frames Spektre Capture, Record, Transfer 5 07-16-2012 04:30 PM
Compression with MMC ATI, P frames and B frames for MPEG-2 ? John Capture, Record, Transfer 1 08-20-2011 10:15 PM
JVC HR-7600U problem with TBC turned on, tracking errors at top of screen rodbuilder Capture, Record, Transfer 18 07-04-2011 03:37 AM
VirtualDub - frames inserted? lookouts Capture, Record, Transfer 3 10-15-2006 09:28 AM
