04-18-2017, 12:32 AM
Hello,
i have AIW 9200 + drivers and MMC 9.02 from our forum.
So, i have a lot of problems with VirtualDub capturing, please check link:
https://www.youtube.com/watch?v=jFKGsUYEGnA
Capturing with "Ati Rage Theatre Device" is *impossible (video link) - i can capture only with Microsoft WDM...but...it's ancient and in this case, i don't have all features.
Can you help me, please?
Tine
P.S.: *not only preview is defected ; if i try to capture with "Ati Rage Theatre" i had a lot of dropped frames....
04-18-2017, 01:09 AM
We can't help you with a re-processed YouTube video of a recording of a media player plati8ng a video.
What does "impossible" mean when you say you can't capture with the "Ati Rage Theater"Direct Show device. Do you get an error message? What does the message say? Is the device recognized by VirtualDub? Have you tried uninstalling and re-installing the ATi package? ATI's drivers and software require a certain install sequence -- you must remove all graphics drivers before installing, and boot up using the Windows XP default VGA driver. At bootup do not allow the Windows hardware wizard to automatically load any drivers or capture software.
Have you seen the settings guide at http://www.digitalfaq.com/forum/vide...-settings.html.
04-18-2017, 01:17 AM
Check YT video - and you'll see (that's not media player, but virtual dub, and you will get answers).
04-18-2017, 01:48 AM
I understand what you're saying, but you didn't answer the other questions about how ATI was installed or whether or not you're using settings recommended in the linked capture thread?.
04-18-2017, 02:32 AM
[What does "impossible" mean when you say you can't capture with the "Ati Rage Theater"Direct Show device? Do you get an error message? What does the message say?]
It means, that i got a lot of dropped frames. I saw error message sometimes, but now it's okay (no error messages). Device is recognized by Virtual Dub (you can see at YT video). I tried uninstalling and reinstalling ATI Package and drivers many times.
04-18-2017, 03:14 AM
Have you seen the capture setting recommendations in the advanced capture guide ( http://www.digitalfaq.com/forum/vide...-settings.html)? Is there any major difference between those recommendations and the settings that you are using? You might have the correct Direct Show device selected, but how about the capture pin and capture filter settings in the other setup sections?
If you're using line-level and frame-level tbc's, you shouldn't be dropping frames.
04-18-2017, 03:19 AM
No, no any major difference. Capture pin and capture filter settings is correct (for sure) - it's the same as "Microsoft...." (PAL_H)...
04-18-2017, 07:02 AM
Playback in your video looks like a PAL video standard mismatch. PAL_H as far as I know is a broadcast standard in Belgium, but the VHS tape itself might not be PAL_H. Did you try some other PAL type? What is the tape's country of origin?
And thanks for your patience.
04-18-2017, 07:49 AM
I tried all PAL types. Slovenia.
IMPORTANT: I have same PAL setting at "Ati Rage Theatre" and "Microsoft..." - and on "Microsoft..." it works normal.
04-18-2017, 08:30 AM
Hm. That's not just highly unusual, it's baffling. It's a slight possibility that the 9200 is defective in some way. Do other tapes perform correctly?
[EDIT] I see you mentioned you have drivers that contain MMC 9.02. I can't find that MMC mentioned in the recommended drivers for the 9200/9600 AGP cards. The driver set recommended is here: http://www.digitalfaq.com/forum/vide...html#post14940. It has MMC 8.8. In my own case I'm using AIW 7500 and 9600XT cards with drivers from 2004, but have not installed MMC since 2002 (I never use it).
With your current drivers, are you able to get correct playback using MMC for capture?
One other possibility is that if you have installed an MMC version that doesn't match the version of other Catalyst driver editions, you'll have problems.
04-18-2017, 10:22 AM
Yes.
I knew this drivers for 9200, but didn't work for me (i could install them - error message - INF error), so i tried other pack(s)..
04-18-2017, 11:20 AM
If MMC works, it's a driver problem somewhere. Of course, it could always be the tape (not as likely).
MMC can be used to capture to lossless AVI using huffyuv or other lossless compressors.
The 9200/9600 driver set works, as I tried them myself some time back. I don't know why you had a inf error message with the recommended setup. They installed OK for me. But I now use a different version (Catalyst 45, October 2004) I download from the ATI site years back, before AMD took over. Now that you say MMC plays the tape correctly, the mystery deepens but points to a VirtualDub problem somewhere. And that "inf error" poses other questions, if the installation sequence was correct.
For the time being I'm baffled, unless you want to use MMC instead of Virtualdub. Others have also tried VirtualVCR, here: http://virtualvcr.sourceforge.net/, but I don't recall if you can set up PAL_H, it's been many years since I tried that capture program. For the time being this problem has me at a loss for more answers, but I'll keep researching. At the moment some aspects of this situation just don't make sense.
04-18-2017, 02:20 PM
Judging by other recent threads with capture device + VirtualDub problems, you may way to try other versions of VirtualDub.
To troubleshoot further you could see whether building a graph in GraphEdit works.
04-18-2017, 04:56 PM
The main reason I've not replied to this yet is because I'm trying to figure out my own ATI AIW problem.
1.8/9/10 refused to preview correctly.
1.5 works for preview, but still drops frames.
I finally have time tonight, and will reformat a drive and reinstall Windows fresh. See what happens then.
| Thread |
After capturing VHS with VirtualDub, how to proceed?
Superopa |
12 |
01-13-2017 06:43 AM |
Problem with ATI TV Wonder 600 USB in VirtualDub - no audio?
Zoink187 |
7 |
07-21-2014 04:26 AM |
No audio when capturing with VirtualDub
TylerDurden389 |
17 |
04-15-2014 05:27 PM |
My VHS capturing plan with EasyCap USB and VirtualDub?
Renowned |
2 |
10-15-2013 05:19 PM |
Problem with Virtualdub when filtering...
jrodefeld |
1 |
10-02-2011 04:59 PM |
