07-31-2006, 09:37 PM
manthing manthing is offline
setup is so : digital box feeds via rgb enabled scart to jvc dvd recorder.
question : what aspect ratio should i use? 4:3? 4:3L? 16:9?
or doesn't this setting matter when doing a dvd recording?
all help appreciated.
08-01-2006, 07:52 AM
It matters. Your normal tv feed is 4:3.
Your normal HDTV feed, downconverted, would likely be the 16:9
08-01-2006, 08:05 AM
markatisu markatisu is offline
You know I have never tried recording HD signals with the 16:9 setting. I might have to switch it and see what happens.
