03-03-2019, 04:51 PM
Egon Egon is offline
This is driving me a bit mad.
I have a JVC SR-V101US that plays wonderfully but we had a power outage and now I'm getting audio pops on ONLY vhs tapes that are home movies. Any retail movie is fine. The audio comes from the vrc into a hauppauge wintv 885. I've switched all the cables out, tried different settings, tried a different outlet, tried opening it up to clean the heads, and I just cannot get rid of them.
I'm included a sample of the pops.
03-08-2019, 11:22 AM
Eric-Jan Eric-Jan is offline
To me this sounds like static you hear on a Medium Wave radio, maybe some capacitors got fried by the mains spike ?
Your own tapes have this also with the anti record tap removed ?
Do tapes with only analog sound (lineair track) have this too ?
03-09-2019, 07:15 AM
Commercial tapes often include stereo Hi-Fi audio, and many players default to playing the stereo sound. Many home VHS recordings only had linear sound. Can you select linear or stereo/Hi-Fi audio output on the player? If so see if it is present on the linear track of the commercial tapes.
03-09-2019, 10:28 AM
On the other hand..... it also sounds like a loose wire or metalic part... does it get any worse when you move or knock on the vcr, or any parts connected ?
btw. I see this vcr has a Three-prong power cord ...(this is just a wild guess.....) the earth wire is used before and after the "failure" ? (earth loop comes also in mind) does your house mains have a earth leakage circuit breaker ?
it could be EMI caused by the outage,
https://www.controleng.com/articles/...noise-and-emi/
I guess even plastics rubbing against each other could generate EMI
Does other HiFi sound equipment have the same "noise" ? (earth loop)
Can you try another audio input on the vcr ? this interference is not visible in the video ?
Any Plasma tv screen nearby ?
audio, pop
Regarding audio pitch: A-440 standard on VHS tapes? rocko General Discussion 1 10-11-2015 02:43 PM
Only audio on some U-matic tapes? Winsordawson Capture, Record, Transfer 2 07-25-2014 08:30 AM
Trying to convert my VHS-C tapes to DVD: Have video, but no audio? via Email or PM Capture, Record, Transfer 1 08-05-2012 04:15 PM
Beta home tapes to DVD? How to Convert Betamax to digital? rocko Project Planning, Workflows 4 07-14-2011 11:23 PM
Weird dust on VHS tapes from smoker home mrwhitethc Restore, Filter, Improve Quality 14 07-26-2008 06:24 AM
