01-15-2020, 03:19 AM
swiego swiego is offline
Got a JVC 9911U (original owner) and I’m happy to say it’s held up with roughly 1 tape/month use despite having the build quality of a tin can. Is there anyone out there who has maintained this final JVC? Or, a lead on a service manual & schematics? I’d like to give it a once over or send it to someone who understands the latter most JVCs, to verify it is at spec and perhaps breathe a few more years of life into it.
01-15-2020, 04:00 AM
Main issues are alignment, head cleaning, chassis cleaning, lube.
Funny enough, it's not much different from a car engine. And like a car, you can easily screw up an expensive item with the wrong methods and items.
1. Clean the heads ONLY as needed, not as preventative maintenance. Heads are delicate. (Some people use Q-tips, and it's analogous to cleaning your own intimate/private anatomical parts with sandpaper and a steel brush. Obviously that's bad!)
2. Gravity makes units go out of alignment over time, and it can be affected by head condition as well. This drift must be gently calibrated. The best alignment is done with scopes, but you can eyeball it with experience (which I have).
3. Lube can be badly done, and with the wrong items. I've read stories of morons ruining their decks with WD40. Silicon grease, etc, as needed. Again, not normal maintenance, only done when problems present.
4. Body cleaning is preventative, using soft brushes and canned air, to prevent dust/grime from affecting lube and heads. Just be careful with canned air, you don't want spew.
I thought the service manual for the 9911 was in this forum? If not, for your needs, almost any JVC service manual will do, though obviously get as close as possible (9900, SR-V101, etc).
I actually have a 9911 parts deck, if needed -- but noting it's a part decks because some parts failed/broke.
Deck maintenance can be DIY, but you must be careful. And on your very first clean job, mistakes are common. So if you insist on a DIY, never start with your best deck. Preferably even with a deck that doesn't matter at all (ie a $9 Goodwill VCR).
I could always grade your deck.
Mitsubishi HS-HD2000U maintenance? homefire Capture, Record, Transfer 9 04-26-2024 05:52 PM
Maintenance Related Question JVC-Fan Video Hardware Repair 1 10-20-2018 06:56 PM
JVC S-VHS VCR: HR-S9500U vs. 9911U vs. DVS3U? leeoverstreet Project Planning, Workflows 3 04-11-2018 01:18 AM
Forum maintenance 1/31 admin General Discussion 0 01-31-2017 10:04 PM
Planned maintenance for 9/4 admin General Discussion 0 09-03-2013 09:22 PM
