01-20-2020, 10:11 AM
jjdd jjdd is offline
Hi i did buy from ebay Geneva PF-740 Video Tape Cleaner and it works very good i did replace the old cleaning cloth with Pec Pad 10x10 cm that i did cut to the right size
for the center cleaning pin i did do a custom wedge to hold the new cleaning cloth
i did replace the SQUARE BELT to i did buy the 106mm x 2mm x 2mm from here https://www.ebay.com/itm/SQUARE-BELT...72.m2749.l2649
here are some pictures
File Type: jpg Pic_14_Inside_cleaning_pad _Geneva PF-740.jpg (71.1 KB, 40 downloads)
File Type: jpg Pic_15_Inside_cleaning_pad _Geneva PF-740.jpg (70.1 KB, 27 downloads)
File Type: jpg Pic_16_Inside_cleaning_pad_pin _Geneva PF-740.jpg (69.9 KB, 24 downloads)
File Type: jpg Pic_17_Inside_cleaning_pin_wedge _Geneva PF-740.jpg (89.8 KB, 27 downloads)
File Type: jpg Pic_18_Inside_cleaning_pin_wedge _Geneva PF-740.jpg (60.3 KB, 27 downloads)
File Type: jpg Pic_19_Inside_cleaning_pin_wedge _Geneva PF-740.jpg (81.8 KB, 29 downloads)
The following users thank jjdd for this useful post: BPS2020 (05-16-2020)
01-22-2020, 10:15 AM
What is your intended use for this?
General cleaning of tapes? (not suggested!)
Mold removal?
The reason general cleaning is not suggested is because sometimes start to flake/shed. You have ONE attempt to recover the material with quality. Subsequent plays will be drastically reduced, with heavy noise on screen.
01-22-2020, 10:31 AM
i was thinking General cleaning of tapes that i know is dirty so it does not get to my vhs player
but good to know i have to be careful if i use it
i did have a old vhs tape that a friend did ask to transfer to dvd and it did have some kind of oil on it and my vhs player did drop the picture but that was easy fix offcourse
05-16-2020, 06:52 PM
BPS2020 BPS2020 is offline
Thank you for your help. I need to replace the belt on mine, now I know the right size.
05-16-2020, 08:15 PM
Good
my old belt did get little better when i did heat it up a little with a heat gun
but the new one was off course much better
05-17-2020, 02:04 AM
I'm having trouble finding the right size replacement belt for the PF-740 based on the size you suggested "106mm x 2mm x 2mm"
Ebay & Amazon have tons but I cant find that size. Any suggestion where to look?
Thank You.
05-17-2020, 06:15 AM
Thank You.
i did buy from here https://www.ebay.com/itm/SQUARE-BELT...MAAOSwWbZciNUj
the person on ebay name is "elecments13" https://www.ebay.com/usr/elecments13
i think this is good to itīs 107mm x 2mm https://darel.lv/en/rubber-drive-bel...103060000.html
did find more to google Square Belt 107mm
05-18-2020, 02:56 PM
Thanks for your help.
I just wrote to elecments13.
Asking for 2 belts, 106mm & 107mm.
Waiting for his reply to place an order.
Thanks again, I'l keep you posted when it gets fixed.
05-18-2020, 03:11 PM
Sounds good
Geneva PF-740 tape rewinder-cleaner for moldy tapes? BarryTheCrab Capture, Record, Transfer 3 06-29-2019 03:37 PM
MG Chemical audio/video head cleaner vs. isopropyl alcohol 99%? waloshin Video Hardware Repair 2 12-28-2018 09:46 PM
Panasonic W1 repair gone wrong, images of insides? cedric75018 Video Hardware Repair 2 12-14-2017 03:54 AM
What is the best VCR cleaner Superstar Videography: Cameras, TVs and Players 6 09-25-2010 01:42 AM
VHS tape malfunction, mechanism not rolling tape properly admin Capture, Record, Transfer 0 10-12-2009 10:57 PM
