06-25-2021, 10:00 PM
DrDynaride DrDynaride is offline
I've recently purchased a Toshiba Diomage SV-771 VCR, which was sold as parts or repair. When I got it, I noticed a very loud clicking, which the seller said was happening to it. I soon noticed the clicking was of a worm skipping against the blue cam gear, which is made to move the guide arms to place to load the tape. What's weird about this, is that the guide arms go into place, and back, and then it starts clicking. The tray loading mechanism is hit and miss, sometimes when I first power it up, and hit the open button, it will start clicking, other times it will open the tray, and it will start to click, and I have to push the tray back in by hand. All of the belts are still gripping quite well, which is good, but any advice will be very helpful, thanks!
06-27-2021, 08:26 PM
Dougmc Dougmc is offline
What you dont know if someone took apart and didnt align correctly.
Maybe the cam,mode switch that runs off the main cam may need cleaned.
diomage, stuck gear, toshiba, tray loading, vcr
Clicking sound from homemade tape captures? googoo Capture, Record, Transfer 7 07-30-2020 09:50 AM
Loud hum on optical drive? Reading Bug Copy DVDs, Duplicate, Replicate 5 06-20-2015 12:44 PM
Toshiba DX800 won't play, just makes horrible noise DeeSeven Video Hardware Repair 2 02-17-2013 04:40 AM
How to adjust very loud audio clipping during capture? moxiecat Capture, Record, Transfer 6 03-07-2012 05:37 AM
JVC DR-MX1S DVD recorder makes clicking noise, help! JDiane Video Hardware Repair 3 12-28-2011 05:24 AM
