08-02-2025, 08:59 PM
jham55 jham55 is offline
Hey there.. this deck plays the tape fine but I cannot clear up the video. It gets way better when I press down the back guide post. The video shows it. If I take tension off it comes back up and the picture gets weird again. Not sure how to get it more aligned. Any thoughts?
08-03-2025, 04:40 AM
timtape timtape is offline
No video appears. Possibly one of the guide posts is not fully seating in the slot at the back. Compare it with the other guide.
08-03-2025, 03:51 PM
Got a deck that has the same problem. What you really need are new loading arm gears (arms + guides) .
On mine the P2 guide just slips/ bend toward the drum quickly and then the top picture is messed up, can happen on the other guide aswell i guess.
You can try using crazy blue on the treads, i doubt it'll work
08-03-2025, 04:05 PM
Could be the heads are worn also and the added tension gets the tapes closer to the heads, but yeah, a video would be helpful.
Sony CCD-TRV65E weird object in viewfinder, noise? sebastiaaan Videography: Cameras, TVs and Players 2 02-06-2023 01:35 PM
Panasonic AG-4700 weird intermittent picture issue? rocky72 Video Hardware Repair 9 04-07-2022 10:42 AM
Weird issue when panning? (Hi8 tapes) waloshin Restore, Filter, Improve Quality 6 11-17-2020 06:30 AM
Weird sync issue on copied tapes? koberulz Restore, Filter, Improve Quality 7 09-18-2020 12:33 AM
AG-1980 B&W / color switch weird issue volksjager Capture, Record, Transfer 2 02-18-2012 03:13 PM
