02-08-2023, 04:41 PM
LeBeauLuc LeBeauLuc is offline
Hi guys,
I am trying to figure what is the problem with my combo DVD/VCR, when I first bought it it was acting wonderfully, but one day those annoying horizontal noise start to appear https://www.youtube.com/shorts/naRgArjaEPQ It does the same thing on composite, s-video, component and even HDMI. Yes, it is one of the rare VHS player that can player through HDMI.
I have located the service manual, but it is pretty much useless there is no schematic, only how to disassemble the player, spare parts and some diagnostic tools. I have tried to measure the ESR on the caps on the board, everything is all good within range. I initially thought that It was perhaps a ground loop issue or a filter cap issue. I have tried to ground near the connector directly on the chassis and no improvement. I have spent several hours trying to figure what might be the issue. The only problem that I have figured out is there is something strong that "open" the diode as they let go of the current of both side, but they test fine when pull out of circuit.
Anyone has a clue? So far this thing has been a nightmare to diagnostic.
02-11-2023, 01:44 PM
Some sort of interference patterning.
Maybe internal to unit (failing caps/etc),
Maybe external (bad power, conflicting devices on same/nearby circuits).
The bigger issue is it is worth to fix?
- For the VCR, absolutely not, low end Funai junk.
- For the DVD player, again no, so many DVD players or BD players to replace it with.
VHS really has no business being played to HDMI in NTSC (and mostly not PAL), it gets butchered. That unit probably downgrades the quality first to internal composite anyway, so the HDMI isn't even fed a good signal internally anyway.
What causes this horizontal line noise, how to fix? mikenew02 Capture, Record, Transfer 10 10-04-2021 10:51 PM
Horizontal chroma noise? lupin981 Capture, Record, Transfer 6 01-17-2021 05:42 PM
Horizontal shaking line noise going from bottom to top retractOffer Capture, Record, Transfer 6 04-13-2020 07:10 AM
What causes this thin horizontal white line noise? dima Capture, Record, Transfer 12 01-24-2020 10:02 AM
Toshiba DX800 won't play, just makes horrible noise DeeSeven Video Hardware Repair 2 02-17-2013 04:40 AM
