04-05-2025, 01:51 PM
Townly Townly is offline
Hey all,
I have a Panasonic AG-1980 that sat unused for about 6 months. When I powered it on, a tape was stuck inside and wouldn’t eject or play. I followed TGrant’s instructions and manually turned the worm gear to eject it.
Now when I insert a new tape, it gets pulled in but then ejects right away. Attached are some photos and a video.
Any idea what the problem might be? Or how to fix it?
Appreciate the help!
04-05-2025, 03:57 PM
aramkolt aramkolt is offline
Has it ever been refurbished before? Guessing since it sat that something hardened up, though I can't say I've seen one not "try" to push through the loading cycle a little more than that - this one seems to just immediately turn around the process without any hesitation almost like a sensor that it supposed to be triggered during the load just isn't being triggered and so it reverses as a safety measure intentionally. Could also be that with the manual unload that something got out of alignment too. I do refurb these if you aren't able to figure it out, so PM me if it gets to that.
04-06-2025, 11:51 AM
Yea I had it recapped and refurbished a year or so ago. I've never had loading issues. I read that a dew sensor issue or a dirty worm gear/mode switch could cause it so will need to look into that.
1980g, eject, panasonic, stuck
Panasonic K mechanism ejects tape? milo Video Hardware Repair 6 11-08-2021 02:47 PM
Fixing Panasonic AG-1980 tape jam? Papert Video Hardware Repair 1 12-10-2018 08:46 PM
Panasonic AG-1980 won't play tape, just ejects it? syrist Video Hardware Repair 3 11-23-2016 09:17 AM
Panasonic NV-HS1000 VCR - tape ejects, has test signal? interactive Video Hardware Repair 12 01-25-2015 09:09 AM
Panasonic NV-FS90 ejects the tape after insert thaitobbe Video Hardware Repair 1 09-30-2013 12:39 PM
