01-16-2024, 10:12 PM
DamienC DamienC is offline
Hello!
I have an Ambery TBC in which I bought brand new several years ago for a capture project. At the time it worked great with capturing some old S-VHS and Hi 8 footage I shot back in the day. Since then, the TBC was stored in a sealed container for several years. I recently brought it out with the same
S-VHS deck and cables. Now the image is corrupted when using the TBC, regardless of S-Video or composite connections used.The TBC generates color bars okay though when there is no signal being fed to it.
Footage off the deck bypassing the TBC looks normal too. Any insight or suggestions are appreciated.
01-16-2024, 10:40 PM
timtape timtape is online now
Hi DamienC, I have the same model. Mine also failed after a few years. It was SMD capacitors. They often fail in a wide range of electronic devices including VCR's. I'm a tech so it was an easy repair.
I see you're in LA. There should be an abundance of good techs there who can check it. It only takes 5 minutes to check. Since there arent many SMD caps in it, replacing all of them shouldnt take too much time.
The following users thank timtape for this useful post: DamienC (01-17-2024)
01-16-2024, 11:31 PM
Hey timtape!
Thank you for your reply. I’m glad to see I’m not the only one with this TBC. I haven’t been able to find much info about it recently. I’ll have to find someone to check out the Caps. I’m sure you are right finding someone qualified here in LA.
01-17-2024, 02:27 PM
Great, feel free to report back here after a tech has looked at it.
Tim
Panasonic NV-HS1000 noisy image, random spots? hodgey Video Hardware Repair 15 01-21-2021 05:26 PM
Panasonic AG4700/HS1000 noisy picture, jitter/shaky image, weird audio? ofesad Video Hardware Repair 3 08-15-2019 11:11 AM
Generating and Submitting Sitemap ? Leah Web Development, Design 0 09-04-2014 01:44 AM
Generating and installing SSL certificates in WHM? Brent Web Hosting 0 09-13-2013 06:36 PM
Time zone wrong on the forum? Posts show wrong times? faustine General Discussion 7 08-06-2012 04:32 PM
