05-03-2025, 11:16 PM
tobylars83 tobylars83 is offline
Greeting hope you are doing relatively well.
The JVC VCR HR DVS3U I got from you some time back** is having difficulty ejecting VHS tapes. Is that usually a tape problem or ejection mechanism problem? It takes several ejection attempts to get tapes to eject occasionally. It did give me some trouble with the most recent tape as that tape was twisted up in the mechanism but I was able to save it and capture it finally.
** In 2022, 2.5 years ago. -LS
This question was asked via email. Site Staff no longer answer tech questions via email, so that others may read and benefit from our expertise. Please continue the conversation here. Either login or join as a Free Member, and we can continue troubleshooting your video, photo or web related issue. Thanks for understanding our tech Q&A policies.
05-04-2025, 11:20 PM
I'm always glad to help my past buyers, or at least try to, no matter how many years have passed.
Several possible issues.
It may just be the tape, or tapes(s).
If you're sure it's not more widespread, then I'd look at the tape path. The main resistance is the middle of the path, the widest part for guides to move around. Insert mostly, but sometimes eject.
DIY tip:
- Try to lube the tape track with "white lithium grease" (about $4 for a small tube from Ace Hardware).
- Get a non-cotton (foam) swab, then squeezing the tube, swipe a tiny amount on the swab end.
- Turn off VCR, tapes ejected, unplug even.
- Be very careful and dab several dots along the edge of the guide path, near where the guides rest (when tape NOT inserted), staying far away from the head cylinder.
- Do NOT get any of this on any rubber or plastic!
- I use both hand to keep as steady as possible.
- Take tape, insert. The guides will spread the grease for you.
- Repeat as needed.
- It should be a faint white film, not globs.
- Insert, eject, insert, eject. Your tape is essentially f'ing the VCR during this process. In, out, in, out.
- You can take dry unused swab to remove excess, even start over if you screwed it up.
If you want to first clean the path, use a non-cotton swab, alcohol (70%+ IPA), and clean. Do not get alcohol on the boards, do not douse the swab dripping.
I know you're on the ocean (literally blocks away, right?), and ocean air can be ruinous to video gear. It tends to dry up grease, rust metal, brittle rubber. The salty moisture is what does it.
JVC HR-DVS3 and DVK100 to capture VHS? DigiTime12 Capture, Record, Transfer 3 09-05-2023 04:33 PM
For sale: JVC HR-DVS3-U ThumperStrauss Marketplace 0 09-20-2022 07:40 AM
For sale: JVC HR-DVS3-U (with line TBC) ThumperStrauss Marketplace 0 08-27-2022 02:33 PM
JVC HR-DVS3 menu drifting to the side? hato Video Hardware Repair 1 05-31-2020 12:02 AM
JVC DR-M100 or HR-DVS3 - best option for tape to DVD transfer? heym56 Videography: Cameras, TVs and Players 5 01-15-2016 01:38 PM
