12-28-2012, 09:17 AM
Thor263 Thor263 is offline
Longtime lurker, first time poster!
I have the opportunity to purchase a couple of AG-1980s locally. I know that this VCR is one that needs periodic service and the condition they are in can potentially be all over the place. What are some important things I should try to check before deciding to purchase them? I also may not have the opportunity to actually connect them to a display device until after purchase.
Thanks.
12-28-2012, 10:51 AM
make sure the digital display is nice and bright
listen for any high pitch noise coming from the power supply
(both the display and power supply are easily replaced, but you want to factor that cost in)
load/eject/play/ff/rewind a tape.
make sure to high speed FF and rewind all the way to the ends of a tape.
check all buttons and switches
use a flashlight to look inside for any sign of excessive moisture or filth
if it smells like cigarettes you do not want it
that is about all you can check without hooking it to a TV
The following users thank volksjager for this useful post: Thor263 (01-02-2013)
01-01-2013, 11:07 PM
JMP's Avatar
JMP JMP is offline
Former Site Staff | Computers
Good advice volksjager.
Thanks,
-JMP
Purchase domain name at Namecheap vs. Godaddy? tgjasper Web Hosting 2 12-02-2012 10:27 PM
Problem with Panasonic AG-1980 VCR Superstar Capture, Record, Transfer 2 10-20-2011 01:53 AM
How to view hours of use on AG-1980? jimvhs Video Hardware Repair 1 08-27-2011 07:18 PM
Using the Panasonic 1980 sharpen cyber-junkie Capture, Record, Transfer 13 03-25-2010 06:37 PM
Panasonic AG-1980 as good as JVC S-VHS VCR ? ramrod Restore, Filter, Improve Quality 1 11-13-2009 07:33 PM
