08-08-2013, 11:50 AM
Jpass992 Jpass992 is offline
Just got a non working JVC SR VS20U. The SVHS side works, but the loading basket for the mini dv side seems to have been damaged. Also, when I took off the front panel, everything was fine, but now the left ribbon cable that attaches to the front panel has gotten damaged, so the machine gets power, but needs that cable in order to operate the machine. Would anyone be able to help me with a s/m for this machine or the p/n for that cable? Also, would anyone be interested in this for parts? It does come with remote and manual. If interested, pm me and we could work out a deal.
08-08-2013, 10:14 PM
i tend to avoid these decks - the mini-dv sides are always borked it seems.
if you have mini-dv tapes just use a camcorder
i have a bunch of JVC ribbon cables - (the thin white ones)
would need to know length and how many conductors - pic would help
08-09-2013, 11:47 AM
Ok, I am going to need four things for this deck. First off, I'm going to need the 18 pin ribbon cable that attaches toLPA10126 Display PWB Assy. Next, I'm going to need the 16 pin ribbon cable that attaches to LPB10126 Jack PWB Assy. Last two things I need are the tape door slot for the mini dv side and I also need the mini cassette housing assy as that is what was damaged.
08-09-2013, 12:53 PM
probably best off buying a parts deck if you need that much.
genuine JVC parts are STUPIDLY expensive new.
08-09-2013, 01:22 PM
Do you happen to have those ribbon cables?
08-09-2013, 01:24 PM
how long are they?
most of the ones i have are from VCRs and DVD recorders and dont have that many pins.
08-09-2013, 01:44 PM
The ones I need are 18 pin and 16 pin.
08-09-2013, 01:52 PM
how long are they?
a 6 inch long cable wont do you any good if you need a 10 inch one
08-09-2013, 02:12 PM
They are both a little over 3.5 inches, but less than 4 inches.
08-09-2013, 02:25 PM
sorry - just looked and the biggest i have is 14 pin
08-09-2013, 02:36 PM
oh well, do you know any other place I can get them from?
08-09-2013, 03:05 PM
direct from JVC - just be prepared to pay out the ass and wait a month.
08-09-2013, 03:44 PM
Well, JVC has one of the cables, but not the other. For the busted cable, they only want $3.17 for it. The other cable they no longer have. Do you have any parts JVC SVHS mini dv decks?
08-09-2013, 03:52 PM
i dont have any combo deck at all right now - just a couple parts VCR's
08-09-2013, 03:54 PM
What models?
08-09-2013, 04:06 PM
HR-S4500U and SR-V10U
JVC HM-DH30000U troubles... Jpass992 Video Hardware Repair 13 10-17-2012 06:12 PM
Strange JVC SR-VS20U menu problem volksjager Capture, Record, Transfer 2 04-10-2012 01:22 PM
Trouble with v1900 AIW, ATI shut itself down? Tom_n_Jonna Capture, Record, Transfer 2 06-21-2007 08:51 PM
Trouble with TBC...HELP! Tom_n_Jonna Restore, Filter, Improve Quality 3 01-21-2006 12:39 AM
Having some trouble... Daniel Capture, Record, Transfer 9 06-06-2005 10:25 AM
