11-07-2020, 02:00 AM
Glitchy Windows 3.1 Glitchy Windows 3.1 is offline
Hello,
This is an update to previous threads have made concerning virtualdub not working on Windows 10 (thread here http://www.digitalfaq.com/forum/vide...g-windows.html ). And to summarize what I was going to do was that I was going to use a Windows 7 laptop but had an administrator password that was asked when installing drivers. With that being said, I got another Windows 7 laptop (broken screen but works when plugged to external monitor.
As of writing this thread, I have used virtualdub's capturing and it worked well with no crashes nor non-responsive non-sense. Now as you can tell from the title it does have one, fixable, but somewhat annoying problem. It captures VHS tapes at a resolution of 352 x 480 which looks like a rectangle. (See attachment "Original capture")
Now like I said, it is very fixable as I can just go into my video editing program and switch it to 480 x 352. (see attachment "corrected in video editing program") However, it is rather annoying to do that all the time and was wondering if there was a way to fix that minor, inconvenient, issue. Now if it cannot be fixed or is something I have to live with well it is fine with me but was just wondering if there is a way to fix it.
Secondly, I don't remember what thread it was but there was a user who sent this video ( https://youtu.be/sn_TDa9zY1c ). But I do remember LordSmurf saying there was some methods or steps he did no cover on which made me want to ask if there was a thread that covers on deinterlacing and other "techniques" to make the VHS footage better.
11-07-2020, 02:08 AM
You never use 480x352, that's compliant to nothing.
11-07-2020, 02:50 AM
Then what should I use for the resolution?
11-07-2020, 02:53 AM
For NTSC, an x480, probably 640x480 if you want 4x3 AR.
352x480 is valid, different AR is all.
11-07-2020, 03:00 AM
I don't recall seeing a 640x480 option in the video settings. As I believe I went to video > capture pin and then change the resolution to whatever.
11-07-2020, 03:04 AM
capture mode
Video > set custom format
Ideally, you'll use 720x480 for capture.
But 640x480 can be done. Most editors will rightfully say that is an invalid resolution, however.
Restoring 8mm/Hi8/VHS VirtualDub captures? willow5 Restore, Filter, Improve Quality 35 03-26-2019 09:46 PM
Unattended VirtualDub captures? via Email or PM Capture, Record, Transfer 4 08-06-2017 11:28 AM
Set aspect ratio in VirtualDub for 352x480 premiumcapture Restore, Filter, Improve Quality 4 12-27-2013 08:52 PM
352x480 vs 720x480 for VHS captures premiumcapture Capture, Record, Transfer 6 12-27-2013 11:04 AM
Capture resolution choice - 352x480 not in VirtualDub options Mejnour Capture, Record, Transfer 1 09-28-2013 06:52 PM
