03-13-2021, 07:31 AM
ScrumpyDaniel ScrumpyDaniel is offline
Hi all,
New here, and new to this process and I hope this is the correct section!.
I'm capturing some VHS using a cheap capture device (SVG 2.0 A3) and powerdirector, however I notice that these lines appear every now and then, would this be the VHS tape itself, the capture device or the VCR that I'm using? How can I stop this? I have attached an image to the post.
In this case you can see it's the pink line on the right hand side.
I will be hopefully getting a better capture device soon.
Thanks!
03-13-2021, 07:56 AM
ThomasFan1945Pro ThomasFan1945Pro is offline
I don't know what that is. Also, that capture card is bad. You need a better capture card, like Dazzle DVC100.
03-13-2021, 08:20 AM
Do you see the artifacts when connected from the VCR to TV? They look like data loss to me since you are using the wrong software and dodgy hardware.
03-13-2021, 02:13 PM
Cheers for the help guys. Proper newbie when it comes to this!
What would be a suggested budget capture device & software to use? Have tried VirtualDub and OBS and both seem good but I reckon it's the capture device that is letting me down.
03-13-2021, 03:52 PM
Why did I just say a Dazzle DVC100 in my earlier comment? Another thing, I've been on this forum for more than 3 months.
03-27-2021, 06:20 PM
What OS?
ATI 600 USB is one of the better quality cards, or clones for certain problem OS.
Also remember to check the marketplace subforum: http://www.digitalFAQ.com/forum/marketplace/
No. OBS is screen recording software, not analog capture software. Wrong tool.
Both hardware and software are failing you.
Lines appearing in captured video, what's wrong? rocksolid87 Capture, Record, Transfer 2 01-09-2021 12:40 PM
Strange Color Bars appearing in 8mm Transfer deadbeatdad Restore, Filter, Improve Quality 2 07-30-2020 04:22 PM
White specs appearing every few seconds on top of video? retractOffer Capture, Record, Transfer 7 04-20-2020 07:59 AM
Video capture card that would capture all lines in NTSC? alltruefalse Capture, Record, Transfer 3 12-29-2018 01:48 AM
Black lines appearing on all video playback ross2017 Video Hardware Repair 5 10-14-2017 01:34 PM
