01-28-2008, 02:21 PM
http://www.ecost.com/Detail.aspx?edp=39314701
For those who have a sudden interest in a good machine that will encode well from analog/SD sources, as well as clean up VHS quality.
01-29-2008, 02:21 AM
I love my JVC
01-29-2008, 02:50 AM
so should i get this and the philips?
01-29-2008, 02:54 AM
got this stupid error trying to order it
ADODB.Command error '800a0d5d'
Application uses a value of the wrong type for the current operation.
/co_ecost/div_ecost/shop/checkout/checkout_submit_lib.asp, line 496
01-29-2008, 02:59 AM
ok. i dont understand why you say its the best but everyone else says it doesnt work for long
whats up with the loading problem?
01-29-2008, 05:41 AM
I have the JVC DRM-10S, it really is the best you could get, especially if you use S-VHS cables to connect it. I also tried adding it to yhe cart, no issue for me. Try ordering it again....
01-29-2008, 05:51 AM
have not had any problem with my JVC
01-29-2008, 06:38 AM
The JVC does not do 16:9 for HD, nor does it have a digital tuner.
This machine is best for traditional sources, specially VHS.
The other thread mentioned HD material, hence the Philips 3575 was suggested.
01-29-2008, 07:02 AM
im just going to order it by phone
01-29-2008, 07:03 AM
should i get this or no
Electronics Replacement Warranty 1 year 2 year?
01-29-2008, 09:13 AM
you can if you like, though often warenties for non "big ticket" items are not worth getting, and you're just giving them more money, for nothing IMO. Also, this machine is getting harder and harder to accquire, so I doubt they could find you a replacement
01-29-2008, 10:04 AM
ok bought it.
01-29-2008, 10:56 AM
"LOADING" is a generic error message that flashes on screen. It might as well say "HELP ME!" instead. It can vary from a blown power supply fuse or capacitor, or simply using a dirty or crappy disc. The very first JVC machines used cheap Chinese capacitors (MANY items from this time period were bitten by them, including AMD and others), which fizzled out and had to be replaced. You replace them with larger, better-made ones, problem is gone. That's what JVC did. Refurbs are almost always better quality than when originally sold.
NOTE: Turn power save mode OFF when not using for timer recordings.
01-29-2008, 10:58 AM
this is going to be good cause i been finding some sneaky retail cartoons on vhs at the goodwill and other places like that for a dollar each and some mighty ducks cartoon episodes and bunch of other things so this will help me out a bunch. i just need a vcr now that will be good
01-30-2008, 07:50 AM
After the first JVC I bought from Ecost was a dud, I got another one, and it has worked like a champ ever since. So, if at first it don't succeed, try,try again
02-02-2008, 01:12 AM
I already own this machine but I might get another as a backup. I love the quailty on it and I pretty much only us it for older vhs/laser beta tapes anyway
02-02-2008, 01:19 AM
dang!!!! It must have sold out. I do not see it listed
02-03-2008, 08:24 AM
02-03-2008, 08:38 AM
glad i got it
02-03-2008, 12:27 PM
bummer
| Thread |
JVC DVD recorders
MagnificentMarcus |
2 |
06-11-2007 11:30 AM |
HD-TVs, DVD Recorders, Blu-Ray and HD-DVDs????
MOTUfan |
Videography: Cameras, TVs and Players |
30 |
03-19-2006 02:36 PM |
HDTV DVD recorders? Looking for positive reviews...
Neuroslicer |
0 |
12-30-2005 03:41 AM |
DVD Recorders
gatch72 |
29 |
07-23-2005 12:27 PM |
DVD recorders with harddrives?
MagnificentMarcus |
3 |
07-02-2005 05:16 AM |
