09-04-2023, 11:57 PM
DigiTime12 DigiTime12 is offline
I’ve recently sourced some equipment for different types of captures for my family, first up are all old VHS and VHS-C tapes and I want to capture them in the best quality I can within reason of course. I have the JVC HR-DVS3 and have ordered a DVK-100, and will connect these with S Video and use virtual dub for as close to lossless capture as I can get and then compress the file for easier viewing, whilst keeping originals stored somewhere. I’m just a bit puzzled as the best way to go about this
First question is: since my JVC VCR has a TBC, should I still get an ES15 in between the VCR and DVK? And if so would i keep the TBC running on the VCR or use the Es15 instead?
Secondly: Would I need to mess around with lots of settings with the DVK or do you generally just use it as a pass through TBC and ignore a lot of the colour related settings on it?
Thirdly: I have some Video8 tapes of my own that I intent to recapture properly as I did them recently via FireWire which I now know isn’t ideal. I used a Sony Digital8 handycam DCR-TRV460E which has S video as well, so would S video give me better quality? And would I have a benefit running the camera through the DVK and or ES15 as well? And in doing so would I still use the TBC on my camera if I did run through the ES15/DVK?
Thanks guys, trying my best to get an understanding but sometimes it’s a bit overwhelming trying to gather the best information so thought I’d directly ask on here.
Last edited by DigiTime12; 09-04-2023 at 11:59 PM. Reason: Capture card is IO Data GV-USB2
09-05-2023, 12:50 AM
1- Use what you you've got until you run into problems, then deal with them accordingly.
2- The DVK-100 is a chroma keyer, not sure how TBC is implemented in it. I would capture without it first and see how it goes. Use its proc amp for unusual tapes where levels are way off.
3- You will see a slight better difference when you capture over S-Video. Though, Do your own comparison, don't take anybody's word for it, If you see the difference is not worth a recapture, that's all what matters, Not sure? post before and after samples.
09-05-2023, 02:07 AM
Use an ES-15-type stabiliser only if the TBC of the JVC can't do the job ie it can't correct the wiggles/wavy edges. If you do have to resort to using an ES-15, switch the JVC TBC off.
I have a DVK-200 and find the brightness and contrast controls on it are great for adjusting the levels using the VDub histogram. Precise knob control verses moving sliders with the mouse/arrow keys.
Don't "follow" a VCR's (or camcorder) TBC with the ES-15. It's either/or. So, if the camcorder TBC is on, leave the ES-15 out of the workflow (as for a VCR).
As for the DVK in the camcorder chain, let's see what Lordsmurf says.
Re Firewire verses S-Video, I agree with Latreche. Do a test comparison. NTSC DV has a lower colour thingee (4.1.1) than PAL, which is 4.2.0; I can't tell the difference between PAL DV and S-Video here but I suspect the recommendation for NTSC land would be to capture analogue S-Video in preference to DV.
09-05-2023, 04:33 PM
Thanks guys, much appreciated, I will do a few tests and report back, capture card hasn't arrived yet from Japan so cant do an S-Video test just yet but will do when I can.
dvk-100, dvs3, es15, s video, trv460e
For sale: JVC HR-DVS3-U ThumperStrauss Marketplace 0 09-20-2022 07:40 AM
For sale: JVC HR-DVS3-U (with line TBC) ThumperStrauss Marketplace 0 08-27-2022 02:33 PM
Capture chain I/O for ES10 and DVK100? theredone1986 Capture, Record, Transfer 5 09-07-2020 11:53 AM
JVC HR-DVS3 menu drifting to the side? hato Video Hardware Repair 1 05-31-2020 12:02 AM
JVC DR-M100 or HR-DVS3 - best option for tape to DVD transfer? heym56 Videography: Cameras, TVs and Players 5 01-15-2016 01:38 PM
