10-24-2021, 04:00 AM
chrisbati chrisbati is offline
Hello,
I have an ATI 600 USB which doesn't work on my main PC but works on my laptop.
They're both win10 but my PC runs with Nvidia card and my laptot with AMD card.
I suspect the issue may be the nvidia card.
So I would like to try to add a second graphic card to my main pc (an AMD one).
Is that a good idea, someone already try to do that with success ?
Thanks for any advice.
Kind regards,
Chrisbati
10-25-2021, 04:23 PM
ffmpeguserss ffmpeguserss is offline
I'm thinking if it's the nvidia card interfering with the ATI 600 then maybe replace the nvidia with the AMD, but I'm guessing you want to keep the nvidia in there. Also there might not be an extra slot for two cards anyway but I could be wrong.
Hmm, perhaps one thing to try is to revert to the basic display adapter somehow (maybe there's a built-in DVI or VGA port on the PC) and see if the ATI 600 would work. I'm guessing if you have the nvidia drivers it might be safe to try as you can reinstall if something goes wrong.
10-25-2021, 07:34 PM
It is Nvidia.
LG GRAM 17 UDH Graphics 620 Mejnour Computers 2 03-06-2019 03:09 PM
Should you bake your graphics card? Divinejames Computers 2 01-27-2019 01:41 PM
ATI AIW list of cards complete? x800 cards good? Amaze Capture, Record, Transfer 4 01-02-2016 02:55 PM
Do ATI All In Wonder cards or ATI TV 600/650 cards capture both PAL and NTSC video? kpmedia Capture, Record, Transfer 0 06-16-2011 05:44 PM
Graphics card... ATI Radeon is the best ? Superstar Computers 1 07-25-2009 02:46 PM
