04-13-2022, 10:18 PM
jsj2251 jsj2251 is offline
(I attached the image file below.)
sony ccd-sc7 Hi8
TBC(x) DNR(x) (Not seen in the manual or menu.)
sony ccd-trv67 Hi8
TBC(o) DNR(o)
-workflow-
camcorder s-video -> gv-usb2 capture card -> AmarecTV huffyuv
Why does sc7 look better than trv67 when I captured it in the same environment?
In addition, sc7 does not have tbc and dnr.
04-14-2022, 02:48 AM
No it doesn't, The camcorder with TBC/DNR got rid of all chroma noise present as greenish tone and the luma is sharper, hence little noisier. The other camcorder is soft and has more chroma stains.
The following users thank latreche34 for this useful post: lordsmurf (04-15-2022)
04-14-2022, 04:53 AM
lollo2 lollo2 is offline
Could you try a capture from trv67 with NR off for a better comparison? It can be one of those cases where "edit" mode (sort of) is not ideal (although the chroma noise can be reduced in post-processing).
A sample of the HuffYUV videos is better than compressed images.
The following users thank lollo2 for this useful post: lordsmurf (04-15-2022)
First capture results, settings, advice? mrmuy97 Capture, Record, Transfer 7 02-06-2023 02:13 AM
PAL Hi8 / Video8 camcorders for capture? Asbesto Capture, Record, Transfer 1 11-24-2018 08:04 AM
Do old VHS camcorders capture stereo sound? Andyroo Capture, Record, Transfer 4 11-07-2018 01:08 PM
Analog capture to digital has bad results! vbendezu Capture, Record, Transfer 10 10-11-2015 09:16 AM
VHS capture - how to get best results from JVC HR-DVS3EU? AJAX1 Capture, Record, Transfer 9 04-04-2015 09:04 PM
