06-12-2024, 06:12 AM
Thermaltake Thermaltake is offline
Hi, I was planning maybe to sell my HS-1000 which I rebuild and it's working without any problems. I have few VCRs now, and was kind of wondering is it worth replacing HS-1000 with FS200 ?
06-12-2024, 06:40 AM
enois enois is offline
Probably, from consumer Panasonic S-VHS with TBC, NV-HS-1000 is not the best: NV-FS200 is highly regarded but is old model and can have capacitors issue, I would consider as an alternative NV-HD950.
06-12-2024, 06:56 AM
Caps are not problem at all I replace all of them with new high quality ones in my VCRs plus other inspection.
Did you test HD950 ?
I was reading and someone put in one of the topics that picture on it is a bit sharper comparing it to other VCRs, don't know about TBC on it how is it processing is it any better than on HS-1000 and FS200 ?
06-12-2024, 12:01 PM
Read this one comment
https://www.digitalFAQ.com/forum/vcr...html#post53737
Look into DOC between the pair.
The following users thank lordsmurf for this useful post: Thermaltake (06-12-2024)
06-12-2024, 12:21 PM
I did, tnx.
I think I will sell HS-1000 and get FS200.
What do you think about NV-V8000 is that combo VHS-S and VHS-C any good ?
Is it comparable to FS200 and NS-1000 in any way ?
Panasonic NV-FS200 vs. Panasonic AG4700? lojelo5 Project Planning, Workflows 1 12-06-2020 11:00 AM
Panasonic NV-FS200, Panasonic NV-HS1000 or JVC HM-DR10000? puleddu Project Planning, Workflows 15 09-13-2020 04:59 PM
Panasonic AG-7350 or Panasonic NV-FS200 for digitizing tapes? simo1427 Capture, Record, Transfer 3 05-21-2018 04:19 PM
Which is better: Panasonic NV-FS200, AG-1980, AG-4700, NV-HS1000? Jgmr014 Capture, Record, Transfer 1 07-05-2016 09:16 AM
Panasonic AG-5700E vs Panasonic NV-HS1000 for transferring tapes? tsakodim Capture, Record, Transfer 8 12-31-2014 10:00 AM
