06-30-2025, 08:55 AM
AdamSmithee AdamSmithee is offline
Hi, I am trying to capture the picture and audio from a beta tape using a Sony SL-F60 beta player, using a BNC to RCA adapter and a Pinnacle MovieBox 510 capturer, however although my TV shows the picture in color, when I use virtualdub it shows the picture only in black and white. Any solution? Thank you very much in advance
07-08-2025, 09:14 PM
Welcome.
B&W issues are generally PAL/NTSC mismatch. It may just need proper settings adjusted.
But the BNC<>RCA adapter may be faulty, comparable to the common SCART<>RCA issues. The quality of the adapter really matters.
The 510 cards also tend to work best with NTSC, not PAL, even if it "does both".
07-09-2025, 04:10 AM
timtape timtape is offline
Your title is a little misleading. The color picture on your TV indicates the Beta VCR's color signal is OK.
ADVC-110 capture only black and white image? Witzker Capture, Record, Transfer 2 02-24-2024 04:34 AM
VirtualDub preview displays blue screen, black lines? andrewprjnn1 Capture, Record, Transfer 2 01-10-2024 11:10 AM
VHS Software displays black lines, splitting video JJtheJJpro Capture, Record, Transfer 9 04-10-2020 03:05 PM
Site feedback: Responsive (Beta) skin displays CODE without line breaks msgohan General Discussion 3 04-08-2020 11:47 AM
Best BETA VCR for image quality? lordsmurf Capture, Record, Transfer 6 02-29-2008 04:30 AM
