03-04-2024, 03:25 AM
Marvolo Marvolo is offline
Hello,
I have been dealing with capturing analog 8mm tapes and I'm trying to figure out which capture chain (and player) yields the best results.
Here are 2 clips which all show the same sequence.
One has been captured by a professional transfer service right into DV-AVI (player, setup, capture chain is unknown, however, MediaInfo lists a DVCPRO codec for the respective DV-AVI files).
The other file shows my own attempt of capturing. I'm using a Sony EV-S9000E (PAL) Video/Hi8 Deck, connected via S-Video to a Panasonic EH 575 which is then connected via HDMI to a Blackmagic Intensity 4K Pro Capture Card capturing in 4:2:2 HuffYuf lossless AVI --> I'm following this guide here in terms of capture setup because it was said to yield the best possible results for analog capture.
Now here is the comparison: one by a professional transfer service done into DV-AVI with unknown capture gear and setup and the other one done by myself with the above-mentioned gear and capture chain. What differences do you see? Which would you think of as "better"? (I used an external hoster since the forum has a limit of only 99MB, which, using the original unaltered clips without re-encoding, is too little even for the DV-files that are by technical standard more compressed than the HuffYuf ones):
Sequence 1 (Transfer Service): https://we.tl/t-jPxxdJVzrR
Sequence 1 (own capture): https://we.tl/t-PaMCxJLohr
Sequence 2 (Transfer Service): https://we.tl/t-C0F6s8PaWl
Sequence 2 (own capture): https://we.tl/t-aiVLwAsUEk
I can see quite some differences between the two different formats and capture chains. What do you see?
03-04-2024, 08:39 AM
KhAoS182 KhAoS182 is offline
Sorry but all is wrong... Why to HDMI? Why to HD and not SD?
03-04-2024, 08:41 AM
Nothing is captured in HD. HDMI doesn't necessarily mean HD. Read the guide that I've linked above. If you had looked at the files I've attached, you'd have seen that none of them are in HD either.
03-04-2024, 09:58 AM
The DV files look to be de-interlaced, chroma suffered the most, For better comparison you should have de-interlaced your files. I see a lot of line jitter, Is the deck's line TBC on?
HDMI output from certain legacy DVD recorders is okay.
03-04-2024, 10:04 AM
Originally Posted by latreche34 View Post
The DV files look to be de-interlaced, chroma suffered the most, For better comparison you should have de-interlaced the files. I see a lot of line jitter, does the camcorder equipped with line TBC?
The DV files aren't de-interlaced. Because DV is - per definition - interlaced. What you are probably referring to is that the Huffyuv-files show excessive combing and interlacing structures. That's because the interlace flag hasn't been set properly with these files due to the capture method. If you tag them as interlaced (e.g. in your editing software (I told Adobe Premiere that these files are interlaced BFF), then they are shown correctly).
If I play them using VLC Media Player they look horribly jaggy because they don't have a proper interlace flag implemented for some reason. Same thing about aspect ratio. The Huffyuv-Files seem to have an aspect ratio flag saying 5:4 wheras the DV-files correctly have an aspect ratio flag of 4:3.
Something about these flags must have gone wrong during capture - but you can easily tell your editing software how to "interpret the files".
Also, de-interlacing analog material is never a good idea. Analog material is always interlaced - so it's best to keep it as it is. Modern TVs or players can easily handle it by deinterlacing themselves. No need to mess up the material by forcing deinterlacing.
Especially since it is technically still a 576i output. I set the DVD recorder to output a PAL 576i signal. So either way, it's got nothing to do with HD anyway.
03-04-2024, 10:24 AM
QTGMC interlacing is fine, I don't trust hardware de-interlacing even the $3,000 LG OLED I have, it does a horrible job at interlaced videos, not bad for 1080i, but 480i de-interlacing is just an after though for almost every device made in the last 10 years or so. Watch interlaced only if you have an old school CRT TV if you can live with the flicker.
03-04-2024, 02:20 PM
aramkolt aramkolt is offline
Hmm. Something odd seems to be going on with both, or it could be my playback hardware just using VLC. It's as though every other line is a slightly different color, like sky is blue with slightly more purple line in a repeating pattern. In times of no motion, you shouldn't really be able to see any sort of every other line patterning and even so, it should only be in the areas where there are motion and not static colors like the sky. See attached screenshot of this still relatively still part and check out the sky. This is of your capture, but I also see it in the professional capture as well. Could be the way the tape was recorded maybe where the odd fields somehow got recorded at different color levels?
File Type: jpg Screenshot 2024-03-04 at 3.15.00 PM.jpg (89.2 KB, 17 downloads)
03-04-2024, 02:36 PM
Yes. If you're referring to those fine horizontal / parallel lines in monochrome areas such as the sky: I got them in all of my dozen tapes. It seems as if that was a technical fault with my video8 camcorder as it got recorded on every tape using that specific camcorder.
I understand that there's an Avisynth script to make them go away, though.
03-04-2024, 06:13 PM
I think he is talking about the entire frame tone, One field is greenish, the other field is blueish, I noticed that on the lossless sample only, The DV file has identical fields' tone.
03-04-2024, 09:34 PM
mrmuy97 mrmuy97 is offline
Originally Posted by Marvolo View Post
What differences do you see? [...] I can see quite some differences
Slightly better detail on your captures, maybe 5-10% improvement.
Color is off with both workflows, work is needed if that's something you're doing for these.
Depends on the situation.
- If the footage is super sentimental, rare, critically important, and must be kept as highest possible quality, then your new captures plus editing will be better.
- If the footage is "I'm using this sweet camcorder, I'm zooming in and out," then I'd take the previous captures and be done, and that would be better.
It depends how you factor in all your time spent to recapture, for it to be a tiny bit more detailed (which no one will notice given the overall quality), then all your time spent doing additional work on the new captures. Everyone has different valuations for this.
Keep in mind it currently takes a pretty high-end Nvidia desktop GPU to have QTGMC running close to realtime FPS while deinterlacing this type of SD video.
Regardless of what AI upscaling and other goodies the AppleTV and Nvidia Shield currently have in their toolbox, they're not matching manual SD preparation quite yet.
So, yes, any device "can easily handle" deinterlacing on its own. But there's still a visible quality difference in most cases. No one is saying deinterlace the archival masters. Just the files for streaming, sharing, etc.
proper vcr+line tbc ---(Y/C)--> proper frame tbc or "tbc-ish" ---(Y/C)--> capture
03-05-2024, 03:00 AM
Where exactly do you see this improvement?
Here is a frame-by-frame comparison between the DV capture and my own DIY-HuffYUV-capture:
https://imgsli.com/MjQ0ODU5
While I cannot tell differences with regard to better details, that is, the 5-10% improvement that you are seeing, what I see is that the DV seems to have a little lesser brightness or gain which results in more fine structures that are preserved (e.g. cloud outlines in the sky). My own capture seems to be a tad over-exposed causing fine structures and details to be washed away in the sky (clouds).
In this scene here it all becomes even more apparent:
https://imgsli.com/MjQ0ODY2
03-05-2024, 08:09 AM
DV brightness gain is more accurate than the lossless capture, This is one of the reasons why BM cards are not recommended for analog tape sources, You can tone down the gain in the crossbar, Also the sharpness created ringing and dark edges. DV suffers from chroma as I mentioned above and it is pumped up a little bit.
03-05-2024, 08:21 AM
You can tone down the gain in the crossbar, .
Unfortunately, I can't control anything via proc amp. This is due to the way I capture using a Panasonic DVD Recorder as external TBC that gives out a HDMI signal right into the BM Intensity Pro. Since I'm not using the analog inputs of the card, I don't have any proc amp tools but have to take the digital signal that's coming out of the Panasonic Recorder. If anything, I would have to insert an external proc amp device between the Hi8 deck and the Panasonic if I wanted to tweak the signal.
06-22-2025, 08:09 AM
Bester Bester is offline
Doesn't the Sony EV-S9000E already have a TBC built in? Why did you opt to use a pass through TBC as well?
Edit: Found it in the Manual. Page 48. https://archive.org/details/manual_EVS9000E_OM_SONY_EN
06-22-2025, 12:14 PM
I actually wouldn't be too surprised if the entire capture chain for the "pro" service was just a Digital8 camera outputting DV.
I've meant to do similar tests with the NTSC equivalent EV-S7000 to see if it does better than D8 camcorders, but haven't gotten around to it.
06-23-2025, 01:15 AM
This is my conundrum.
I already have a Hi8 Camcorder (Sony CCD-TR748E). It has built-in Line TBC and DNR (independent of eachother).
I've seen one for sale but is there any point getting one of those dedicated decks.
06-23-2025, 02:46 AM
No, don't even think about getting a home Hi8 deck. They are usually heavily used, they have a common failure of a cam gear, most features it has not needed for normal playback, the price will be well over $500 for even an unknown condition machine.
The following users thank latreche34 for this useful post: Bester (06-23-2025)
06-23-2025, 02:57 AM
You are spot on with the price. That's good to know. I think I'll stick with Sony camcorder.
Speaking of which, are there any particular models that are recommended for Hi8 capture?
Also V8 and D8.
The VCR guide is much more detailed then Camcorder guide.
The following users thank Bester for this useful post: babirusacapture3 (06-25-2025)
06-23-2025, 03:36 AM
Aya_Rei Aya_Rei is offline
Well there is this buyers guide
I myself use a Sony CCD-TRV87, got it refurbished by I & N Electronics.
Also have a CCD-TRV66 for recording. Mainly for its ability to record footage from an A/V source onto tape, like doing that to give art and videos an accurate "VHS" look.
06-23-2025, 06:07 AM
Yeah that's the guide I sae. There is great talk of expanding it into a table but I guess it never happened.
I was hoping to see how mine compared (CCD-TR748E).
What I did spot was this: https://www.digitalfaq.com/forum/vid...html#post80437
latreche34 says: there is no direct analog output path. It's always analog-digital-analog. TBC on/off doesn't change this. (Note that this is different than saying it's DV-compressed. This digitization is uncompressed.)
I wonder if the decks operate differently?
Capturing analog tapes and DV transfer? Nutan General Discussion 5 07-10-2021 09:20 PM
Quick Tips for capturing video tapes (VHS, VHS-C, Video8, Hi8, DV) lordsmurf General Discussion 0 05-23-2014 01:42 PM
Capturing 8mm tapes (Video8, Hi8) TheDrifter363 Capture, Record, Transfer 30 04-15-2014 09:55 PM
Question on timecode and capturing analog tapes moxiecat Capture, Record, Transfer 2 09-06-2011 11:05 AM
