05-17-2026, 12:02 PM
KirVHS KirVHS is offline
This for now contains two videos.
WithoutES18 and WithES18
All i did is Deinterlaed with QTGMC
More carptures soon.
05-17-2026, 04:39 PM
aramkolt aramkolt is offline
Whites are visibly blown out on the without ES18 capture, can tell pretty clearly in the title credits where the actor names are in white see attached. Hard to say if the ES18 capture is also blown out, could possibly be just "less" blown out. Could be on the tape that way if a second generation tape too.
Those scrolling vertical bars towards the end look like they were caused by ground loops, but hard to say if it is on the tape that way or if that's a result of the current setup. You want all of your capture equipment and PC hardware plugged into the same power strip to try to prevent that.
05-17-2026, 10:19 PM
Attachment 20552
Well, its seems to issue tape bc others are fine
I think it’s due to Sharpness in Videoprosessor amplifier (which is for both captures is set for 7 out of 15)
What about of generation, I think it will be because all AD BREAKS were removed.
What frame insertion rate is OK? BarryTheCrab Capture, Record, Transfer 6 02-22-2021 10:41 PM
Best frame rate for VHS, where to set? LAZYWRITER Edit Video, Audio 2 12-31-2020 04:26 AM
Is frame rate rounded? (29.97) Ohayou Edit Video, Audio 13 02-16-2016 05:56 PM
MPEG bit-rate settings in ATI MMC ? rocko Capture, Record, Transfer 3 07-25-2012 01:45 AM
Bit Rate to produce the best picture? deter Encode, Convert for discs 22 02-28-2010 10:25 PM
