05-19-2026, 10:30 AM
fluffykitty fluffykitty is offline
I saw a listing for a Panasonic VCR that can do Blu-Ray as well as VHS. If I recall correctly, it has an HDMI output on the back of the unit, which makes me believe it can upscale. However, even though Panasonic is a reputable company for VCRs, I am not sure that a weird combo box would be very good as a capture source. It's a BD70V
Technology Connections did a video explaining that a RCA to HDMI as well as a HDMI capture card is the best way to digitize VHS tapes, but I don't agree at all. It looks like in that setup, it upscales the VHS.
By the way, isn't OBS not a good capture tool for VHS tapes, as it's primarily for gaming and not optimized for framedrops or even saves the capture as MPEG2? I prefer having MPEG2 because it's easier to deinterlace
05-20-2026, 08:34 AM
The HDMI output of the Panasonic won't work with a capture card, because it has HDCP (High Definition Content Protection) applied to it, even when playing non-Macrovision-encoded tapes. HDMI capture cards are required to detect HDCP and block it from being captured at the hardware level, so no software is able to bypass the block.
There are ways to strip off the HDCP, such as by using an HDMI splitter, but you have to ask if it's worth going through such through just to get a mediocre-quality capture of VHS.
05-20-2026, 05:20 PM
What's your favorite capture card? I saw your video on the Elgato and I went with the ClearClick because you advised against getting Elgato. Do you have a cheap, budget friendly one you like using?
05-21-2026, 12:27 PM
My go-to capture device isn't a card at all, it's the A/V input mode of a Sony DCR-SR100 camcorder. It captures from composite or S-video, has a TBC, and saves the video in 9 Mbps MPEG2 files. The quality is identical to using Sony's standalone "DVDirect" DVD recorders, which you can find dirt cheap because nobody wants to burn DVDs anymore.
Refurbishing a junk JVC S-VHS HR-S7600AM dave_van_damn Video Hardware Repair 14 03-08-2025 06:52 AM
What security junk in Windows XP SP3 should be disabled? captainvic Computers 3 08-17-2022 12:00 PM
Panasonic AG-5700E vs Panasonic NV-HS1000 for transferring tapes? tsakodim Capture, Record, Transfer 8 12-31-2014 10:00 AM
Have Dazzle DVD recorder - but is it junk? AJS3 Capture, Record, Transfer 3 11-24-2014 09:30 AM
Can my Panasonic DMR-ES10EB record Freeview channels from my Panasonic TX-L-32G20B TV Peter_T_Ross Videography: Cameras, TVs and Players 4 09-01-2010 05:20 AM
