03-08-2008, 01:13 AM
Just wanted to know if this Maxell VHS Dry Head Cleaner should be used on my VCR or should I pick up a wet model or what?
03-08-2008, 04:09 AM
Head cleaners really don't help much. Pretty much smear, rub or otherwise squish gunk against heads. The dry cleaners are about as useless as a tape. The wet cleaners (come wet, NOT one you add wet to), are marginally better, but limited lifespan (maybe harder to find now, too).
Personally, I take my machines apart, and use denatured alcohol or 70% isopropyl alcohol, with a non-cotton swab made for cleaning delicate items (like electronics). Just hold one barely damp against the head, rotate.
03-08-2008, 05:44 AM
Cool, thanks as always for the advice LordSmurf, is there any difference between 70% and 91% isopropyl alcohol? Also since I've never done this before is there a proper way to rotate the head? Does it, should it only spin 1 way?
03-08-2008, 05:49 AM
70% minimum
Only spins one way (clockwise)
03-08-2008, 06:43 AM
Thank you LordSmurf, most helpful
03-08-2008, 07:58 AM
I do the same thing.
03-09-2008, 07:41 AM
Same here.
