04-29-2012, 10:04 AM
VideoTechMan VideoTechMan is offline
I was able to snag this from Amazon for $40, after reading the good reviews on the 600 series in the forums.
With this USB device, I should be able to capture lossless .AVI correct? And will I need VirtualDub to capture to AVI (have used Scenalyzer in the past)?
04-29-2012, 01:25 PM
Nightshiver Nightshiver is offline
Yes, you can capture lossless and you will need Vdub to do it.
04-29-2012, 11:17 PM
Great, then I will go ahead and download VDub and when the card arrives then I will test it out. Getting the USB version is good since I can use it on my laptop since I don't have my i7 workstation built yet.
I also have the Happauge 1212 but I only use that for mostly HD sources.
04-30-2012, 12:31 PM
any updates on the guide that was in the works for the 600usb?
ATI All In Wonder video capture card, with capture computer, for sale [SOLD] kpmedia Marketplace 1 05-23-2011 02:09 PM
Looking for used capture card naga Capture, Record, Transfer 6 07-07-2008 09:52 AM
Capture card Wineslurper Capture, Record, Transfer 6 07-12-2005 08:04 AM
