02-25-2014, 05:30 PM
Since a lot of the D-VHS decks came out after the S-VHS decks, I would think the TBCs would be better. Any difference when looking at VHS/SVHS footage?
02-25-2014, 06:17 PM
It's not better. Over time the S-VHS buffer got small, though it was somewhat offset by DDR (double data rate). Eveything after the HR-S9900 has only 2mb instead of 4mb, and it can make a difference at time. Understand that this is a nitpick, however! It does NOT mean the 9600/9800/9900 is worth overpaying for.
A benefit of the D-VHS is that the TBC and stablizer can be on at the same time.
It also has a sync filter similar to the one in a PanasoniC ES10 recorder (passthrough use only), though not as good. However, it works for most tapes.
The big problem is the build quality of D-VHS units, as they part of the 2000s era of JVC hardware. It's not as good as the 1990s gear.
If you can get one for a good price, do it. You won't regret it. But I'd still suggest a plain S-VHS deck of some kind, either JVC or Panasonic (or both).
Capturing on JVC Professional Deck Winsordawson Capture, Record, Transfer 11 02-26-2013 09:23 AM
Do you know your JVC deck? Mejnour General Discussion 2 01-29-2013 09:33 AM
Do you know your JVC deck? Mejnour Marketplace 0 01-28-2013 08:55 PM
Capture Settings for JVC S-VHS deck - Please Help! jrodefeld Capture, Record, Transfer 7 09-06-2011 03:52 AM
Go Dual Deck VCR question. WEW3 Videography: Cameras, TVs and Players 9 07-20-2006 09:13 AM
