09-27-2016, 12:24 AM
Robinthehood Robinthehood is offline
Hi I'm very new at video capture and I'm wondering if anyone can recommend a capture card for windows 10. I have been using an Ezcap for about 6 months I'm very pleased with the results first as mpeg with the bundled software then as avi with Virtualdub now I'm ready to play with something else. I have a Panasonic NV-HS860 SVHS Deck and I'm mostly converting PAL VHS though I do have some NTSC and SECAM tapes. My budget is £300. TIA
Recommended capture options with LG DR-7800? odedia Capture, Record, Transfer 7 06-18-2016 01:50 PM
Capture using Windows 7 and using new capture card? anyango Capture, Record, Transfer 9 02-18-2015 09:19 PM
Recommended capture card with component inputs? metaleonid Capture, Record, Transfer 12 11-17-2013 09:29 PM
Capture card decisions: Windows XP? Really!? Dr. Brule Capture, Record, Transfer 4 07-01-2012 02:10 AM
Advice on VHS capture setup (capture device, proc-amp, recommended connections) Simon76 Capture, Record, Transfer 12 12-23-2010 03:46 AM
