03-04-2018, 05:07 PM
billct97 billct97 is offline
I have finally got a reliable workflow with the addition of the AG-1980, TBC-3000, ATI USB 600 and VirtualDub 1.10.4. I've read quite a lot on this forum and enjoyed others posts with real video and suggestions for making the most of the video they captured. And now I'm running into my own beginners challenges.
Most of my video is off-air NTSC TV shows recorded at EP or SLP. That's why I added the TG Grant restored AG-1980 and it seems that was a very good move as chroma noise seems much better than with the eBay purchased JVC HR-S9800U. I want to make use of filters as needed and so am trying to pick the right ones and set realistic settings. So far using VDub as I figure I should understand that before I attempt avisynth.
I'm working on a quality Windows 10 laptop (S-Video into the ATI 600, screen is not calibrated...yet) and also viewing the VCR output on a Sony TV with composite video and audio inputs for comparison. Both look relatively close but overall it seems to me that the color saturation could be improved.
It seems to me that the first place to start would be a reliable histogram. I was able to get that working in VDub and also captured this short video. I cropped the edges by 20 on all sides for the histogram but removed the crop for the video capture. The short video has 3 sections, the space scene, the scene with the bright lights and the scene where they are sitting. Hopefully this is a good sample. I am confused by the histograms and instead of wasting your time explaining what I think is happening can someone kindly tell me what they think of the video and what the histograms are telling me.
If filtering would help I've read that ColorMill is well regarded. Is there any way to adjust levels while watching the results? If so I haven't been able to figure out how to do this. I'm actually pretty frustrated with having to have Preview and Preview Acceleration enabled for seeing the effects of the filters and then having to go back to Overlay to see video when filters are disabled. Does avisynth make this any easier? Should I just give in now and go with something simpler like avidemux (it looks pretty).
Next up, I posted the video as avi. How do I convert it to mpeg in VDub? I could do it is another program but would rather do everything in VDub if I can.
And final question for the day (I've been at this for over 6 hours so forgive me if I'm not making complete sense). I understand why cropping is bad - you lose the 720x480 format - and I could swear I had read that you should matte instead. I can't figure out how to best accomplish that.
Thanks,
Bill
03-04-2018, 05:28 PM
If the JVC had more chroma noise than a Panasonic, dirty heads were very likely. (Too many people say "clean the heads", a false catch-all for problems. But in this case, on that JVC deck, it's likely. Proper cleaning, too, of course, meaning chamois/foam and 90%+ alcohol.)
Before you do anything with color correction, you must calibrate your monitors.
There's never any way to color correct live in software, but you can do so in the analog hardware (including that really nice TBC-3000 you have). At best, in software, you can preview frames, maybe even in movement (hold down arrow key in VirtualDub, hope it doesn't crash), but not playing. The system can't keep up to realtime. Even NLE cards can struggle with this, and must first render (test encode) test clips.
ColorMill is nice for VirtualDub. I do all my color correction in Premiere (a lot like Photoshop in controls). In the future, I want to look at the free version of DaVinci.
You can't convert to MPEG in VirtualDub. Output to lossless intermediary AVI, and feed it to something like Avidemux 2.5 (not 2.6 or 2.7, but 2.5).
I'm still surprised you're not having issues with VirtualDub capturing on 1.10.x, instead of using 1.9.x as we've mentioned to you quite a few times on the forum. Versions of software matter, newer isn't always better/upgraded.
VirtualDub matting seems complicated because it's done via cropping. Add the resize filter, and all you do is "letterbox/crop to size" to 720x480. OK to close it, then crop on the filter. Crop by 2 pixels (2,4,6,8,10,etc). When you OK that, go to output preview, you'll see the video size is still 720x480, but the cropped image is inside it. You have black masking/fill borders now. (WARNING: Again, VirtualDub 1.10.x and VirtualDub FilterMod (based on 1.10.x) have known problems with masking. Use 1.9.x for this.)
03-05-2018, 01:30 AM
Thanks for your capture sample. As far as I can tell, it's a decent capture of a really bad original recording. Let me ask, did you apply filters during this capture? It looks heavily over sharpened, and the noise especially with bright objects is severe. If your Panasonic is set to increase sharpening, you should restore that sharpen slider to the middle notched position (disabled). Killing the sharpened noise in post-processing destroyed a lot of fine detail.
I would have used v1.9.11 for capture. It's less buggy. Whatever....
For the cleanup to get the sample mpg attached to this post, the only VDub filters I could use were color filters (Color Mill and gradation curves). There was a slight initial levels correction required in Avisynth in the original YUY2 colorspace. Otherwise I had to use Avisynth filters for cleanup. For example, there is no effective VirtualDub filter that addresses DCT ringing effects, sharpening, or aliasing. One speciaized tweak that I applied was a mild NeatVideo VirtualDub plugin.
Working with uncalibrated monitors and TVs is a quick trip to the looney bin.
First of all, you should be looking at histograms in the original colorspace first, not in RGB. Many levels problems and (and should) be solved in YUV first. In YUV the 16 to 235 luminance range is expanded in RGB to 0-255. In RGB you can't any darker than zero or any brighter than 255. If you are in YUV and are already darker than 15 or brighten than 255, what do you think will happen when that overrun is expanded in RGB? Answer: the out of bounds values will be clipped (destroyed).
You likely will never see values darker than y=16 using the ATI 600. It internally clips values below 16. If you look at the true black and darkest areas of your capture, you'll see that at a certain dark point there is no more detail, just a black mass. The commander's uniform and the woman's eyes are examples of dark areas in which detail has been clipped and can't be recovered. Avisynth does have a few filters that can retrieve detail from dark or bright areas where there is slight overrun into the non-safe areas during capture.
In your sample a YUV histogram and detailed analysis of the unaltered capture looks like this:
In the histogram, the top band (white) is the luma (Y) channel. At the left-hand border (darks, where "black" is y = y=16), you;'ll see a sharp "spike" right at the y=16 border and nothing beyond it, no rolloff or extension at all, just a sharp cutoff. This indicates clipping with the ATI 600. If you've made your darkest values bright enough, it's not a problem. Note that if you had included your original black borders vwhen reading the histogram, they would be y=zero originally but the ATI 600 would change that superblack to y=16. In the image above, you;'ll note that I cropped off the side borders and head switching noise before making then histogram and taking then Analyze readings.
In the luma and chroma analysis numbers you"ll see a column labeled "Luma Y". Under that heading are the luma values for this scene. The "minimum" luma value is 16 (with the AI 600, it will never be lower than 16). The "maximum" luma value does indeed exceed 235 (it's actually 253). By viewing this scene in VirtualDub using a pixel reader on this scene, it appears that the brightest values in the non-safe zone beyond 235 are in the blue tail. There is also some visible TV transmission noise along the top border.
The luminance band is concentrated mostly at the dark left side because, of course,this is a very dark scene with very little midrange or bright value.
Here is a YUV histogram and analysis readout for the "lights" scene (frame 209 in the original):
The histogram in this scene has the expected dark-end cutoff at y-16. Although the scene appears dim (there is very little output in the midrange or bright portion of the white band). there are specular highlights somewhere in this image that exceed y-235. When expanded in RGB, the dark cutoff will display as RGB=0 and the bright highlights will appear as 255 in either luma or chroma that starts climbing up the right-hand side of the RGB histogram, even though there is not much output in that bright region.
I worked on this sample with some strong denoisers. To use them I had to return the video to its original state, which was progressive film-based media at 23.976 fps and telecined with 3:2 pulldown for 23.976 fps playback. It was broadcast and captured as interlaced, so the telecine frames were hard-coded (embedded) in the video and had to be removed with an Avisynth inverse telecine filter (TIVTC.dll). Avisynth's Level() filter was used to correct the slight y=255 overflow, and VDub color filters expanded the midrange, the brights somewhat, and saturation. The results were encoded with the HCenc MPEG encoder to get the DVD-compliant MPG sample attached.
Sorry, I don't understand this paragraph. What does Preview and Overlay have to do with VirtualDub filters during capture? Are you using VDub filters during capture? If so, yikes! Don' t ever do that. The proc amp controls are all you need to set during capture.
There's a good free histogram and levels tutorial at Cambridge Photo. It's for still cameras, but the principles for video are exactly the same. The article uses parade-style histograms like those in Photoshop, Premiere, Vegas and VDub's ColorTools.
Understanding histograms Part 1 and Part 2
http://www.cambridgeincolour.com/tut...istograms1.htm
http://www.cambridgeincolour.com/tut...istograms2.htm
There's also a handy video that demonstrates the principles: https://www.youtube.com/watch?v=htqrTTSZp-M.
It's easier in Avisynth, and you don't lose any of the image. The way I cropped the mpg is shown in the explanation below of the Avisynth script I used:
I worked on this sample with some strong denoisers. To use them I hadtoreturn the video to its original state,which was progressive film-based media at 23.976 fps and telecined with 3:2 pulldown for 23.976 fps playback. It was broadcast and captured as interlaced, so the telecine frames were hard-coded (embedded) in the video and had to be removed with an Avisynth inverse telecine filter (TIVTC.dll). Avisynth's Level() filter was used to correct the slight y=255 overflow, and VDub color filters expanded the midrange, the brights somewhat, and saturation. The results were encoded with the HCenc MPEG encoder to get the DVD-compliant MPG sample attached.
Import("D:\Avisynth 2.6\plugins\Santiag_v16.avs")
Import("D:\Avisynth 2.6\plugins\RemoveDirtMC.avs")
Import("D:\Avisynth 2.6\plugins\TemporalDeGrain.avs")
AviSource(E:\forum\faq\billct97\trek3-short.avi")
Levels(16,1.0,255,16,235,dither=true,coring=false)
AssumeTFF()
HqDering()
TFM().TDecimate()
MergeChroma(aWarpSharp2(depth=20).aWarpSharp2(depth=10))
Santiag(2,2)
DeHalo_Alpha()
TemporalDegrain(SAD1=200, SAD2=100, Sigma=6)
RemoveDirtMC(40,false)
GradFun2Dbmod(thr=1.8,mask=false)
grainfactory3(g1str=1, g2str=1, g3str=1)
AddGrainC(2.5,2.5)
Crop(10,4,-10,-2).AddBorders(2,2,2,4)
ConvertToRGB32(interlaced=false)
Return last
Looking at it line by line:
These three lines import the coded lines of an Avisynth filter that is in script form instead of a compiled .dll. This saves me thr trouble of typing dozens of lines of lines of code. The filters are maintained as scripts because they exist in several versions,and each version has to be imported explicitly for specific purposes.
This statement opens and decodes your AVI sample into uncomprfessed video. It also decodes the audio. you want to process a video then, of course,you have to open it first. The name of the built-in function that opens this type of file is AviSource(). The path to the video goes inside the parenethesesd in double quotes.
Levels(16,1.0,255,16,235,dither=true,coring=false) .
the Levels() function manipulates darks, brights, and gamma according to values set in its parameters. The numbered parameters indicate, in the order shown, the following values: value of darks coming in, value of desired gamma (midrange) adjustment, value of brightest elements coming in, darkest value of darks to be output, brightest value of brights to be output. notice that for incoming values of y=255, the function willperforma gradual contraction of 255 values down to 235 to avoid clipping effects. Output will be dithered (transitions between colors and shades in large areas will be smoothed, such as in the sky). Also there should be no coring of output (another way of saying, don't clip).
ConvertToYV12(interlaced=true) performs a high-precision conversion from YUY2 to YV12. Most of the filters to be used after this conversion will work only in YV12. Note that the video's interlaced condition must be stated for proper conversion -- something that many programs don't bother with, with clumsy results and many interpolation errors.
HqDering() is Avisynth add-in that cleans DCT ringing artifacts (edge ghosting and halos),which is a frequemnt villain in tape playback. This filter is usually loaded before deinterlacing or inverse telecine.
TFM().TDecimate()
These two functions are partners in the inverse telecine process.This removes the 2-in5 interlaced frames of 2:3 pulldown and the dup0licate images that are involved. There are two functions separated by a period in the text to effectively form two different statements. These functions are members of the TIVTC Avisynth plugin. After inverse telecine, the video will be pure progressive running at the original films peed of 23.976 fps. When processing is complete, pulldown will be restored during the final encode step.
MergeChroma(aWarpSharp2(depth=20).aWarpSharp2(dept h=10))
This statement runs a sharpener called aWarpSharp2 that tightens colors along edges to prevent chroma shift and bleed effects. MergeChroma effectively means that the filter sharpens chroma only, not luma, to avoid edge halo effects. In the case the sharpener is run twice in succession because there is visible chroma edge overrun, especially with red. The "depth" value is a strength setting.
Santiag(2,2)
DeHalo_Alpha()
Santiag() is an anti-alias filter. Edge aliasing is most noticeable inn the overhead lamps in the lights scene. DeHalo_ALpha helps clear up bright oversharpening edge halos.
This is a strong degraining filter. It makes at least a nominal effort to preserve some of the fine detail that exists under the grain. It's being used here with light to medium values to avoid too much damage. It can result in clay-face and posterizing effects, which is always a problem when cleaning really noisy video.
RemoveDirtMC(40,false) is another filter aimed more at removing general grunge, tape noise, and blemishes. It's also good at removing many spots and dropouts, but it can also remove fine lines and similar objects. The value 40 is a strength setting and the "false" value means that this video isn't grayscale.
GradFun2Dbmod(thr=1.8,mask=false) is a smoother that helps smooth and mask hard contour edges in gradients, such as walls and the sofa cushions, and helpsm avoid hard facial contours after all the previous denosing.
AddGrainC(2.5,2.5)
Removing grain removes a lot of noise butgives a plastic look. The look of film can be restored and many plastic areas can look more detailed by adding very fine film-like grain. grainfactory() is a little more course than AddGrainC().
This statement is two commands in one line.Crop() removes pixels,in this case grungy or unwanted border pixels that have been changed or discolored by processing. This video sample has eight black pixels in the borders at each side, plus 4 pixels of transmission noise along the top and 2 pixels of discoloration at the bottom. However, each side border also has a noisy whitish area running along the interior side of both edges. So the Crop() function removes 10 pixels from the left side, 4 pixels from the top, 10 pixels from the right side, and 2 pixels from the bottom. AddBorders() will then replace the removed pixels with brand new black ones (or the color of your choice. Black is the default. Notice that when the new borders are added, the frame size is now 704x480, which is valid for DVD and for 4:3 BluRay
If you wanted 720x480 for 16Z:9 BluRay (required) or jus wanted to restore the original frame size, you would use AddBorders(10,2,10,4) -- in this case 4 pixels were originally removed from the top and 2 from the bottom, for a total reduction of 6 pixels of vertical height. Because of the colorspace used we can't restore odd numbers of pixels, so the coded restores 4 pixels to the bottom and 2 to the top because thicker bottom borders are usually prettier.
ConvertToRGB32(interlaced=false,matrix="rec601") is a high-precision conversion from the current colorspace to RGB32, which will be used for the VirtualDuib filters. Rec601 is the color matrix for standard definition video.
Return last outputs the results of the last statement in the sequential list of instructions. This statement can be inserted at any line to stop the program where desired and return the results up to that point.
The VirtualDub filters used were ColorMill and gradation curves. Their settings are contained in a text file called a .vcf file. You can load a .vcf file in VirtualDub and it will automatically load the filters involved with their proper settings. It won't work if you don't have ColorMill and gradation curves in your VDub plugins. One other filter used was a tweak with NeatVideo, but I have a different version than the one that comes with the forum's VirtuaklDub 1.9.11 download. I used the ColorMill histogram to check luma and chroma ranges between filter settings.
The attached mpg has 3:2 pulldown (telecine) restored during the encode. It is DVD compliant and plays at 29.97 fps.
The following users thank sanlyn for this useful post: noleterp (03-05-2018), wimvs (03-05-2018)
03-05-2018, 08:59 AM
Quick reply as work is interfering with fun today.
1. I will revert to Virtual Dub v1.9.11 - maybe that will help with some of the odd capture issues I've had.
2. sanlyn your histograms didn't post. Please try and re-post those when you can.
3. Calibrating your monitor - how is this best done?
4. sanlyn, you were correct I had the AG-1980 sharpening just a little over center.
5. no filters on capture. More newbie mistakes on my end. So I want to use the TBC-3000 controls only. But to do that correctly I assume I want to master using histograms and calibrate my monitor??? Anything else that's recommended?
03-05-2018, 06:15 PM
Don't know what might be going haywire there, but I'm looking at the images in this thread at this moment. Nevertheless I'll post another copy (I noticed during my post it was very slow):
space scene (original frame 71):
lights scene (original frame 209):
Notice, you have asked how this best done. It's best done with a specialized kit containing hardware (an analog color probe) and dedicated software (a step-by-step calibration GUI). These kits are not free, but there is no other way to get this desired level of accuracy. There are are cheapo freebie ways, otherwise known as "better than nothing but not far from it), and not all that easy by eye.
Windows 7 & 10 contain a calibration wizard. http://www.onecomputerguy.com/window...rate_color.htm
It's best done with a color probe and special software. Here is an ancient but detailed review of calibrating a PC monitor with the old i1 Display 2 kit from X-rite. Actually, the process and GUI haven't changed much since then, which is why this older review is still posted: X-Rite i1 Display 2 Review.
The products have been changed, but the drill is the same. X-Rite is still the best; the less expensive models shown below are more and more automated and less specific, but they get the job done:
X-Rite i1Display Pro - Display Calibration (EODIS3)
X-Rite ColorMunki Display (CMUNDIS)
X-Rite's less celebrated but still popular Datacolor competitors:
Datacolor Spyder5PRO – Designed for Serious Photographers and Designers (S5P100)
Datacolor Spyder5EXPRESS – Designed for Hobbyist Photographers (S5X100)
Don't forget, your TV should be calibrated as well. Personally I hate staying in a hotel and trying to watch the default settings on TV's there or at people's homes. I prefer to just do something else. To calibrate a TV you need a computer (laptop will do) to run the free HCFR software discussed in an old post entitled GREYSCALE & COLOUR CALIBRATION FOR DUMMIES (OLD VERSION). When you get to this page you'll see the blurb "HEADS UP! AN UPDATED GUIDE IS AVAILABLE!". Ignore it. Only a masochistic and a lottery winner would go for the new hardware and methods. The old post, which covers projectors and TV's, is more workable and easier to understand. HCFR has been updated to work with the newer i1 Display and new Spyders.
Remember that histyograms don't "fix" anything. They just give you information. For proc amp Iusually use the ones for Brightness and Contrast that are in VirtualDub capture, which "connect" to the capture drivers from your copy device -- that capture-time proc amp doesn't belong to VirtualDub. For an external proc amp I still my old SignVideo PA-100 proc amp, but I also use VDub's capture histogram as a double check.
03-07-2018, 10:07 AM
ragu0012 ragu0012 is offline
This thread is so helpful for me as well. Thanks Sanlyn and Lordsmurf.
SVHS PAL AVI cropping/resize/filters suggestion Genu29 Project Planning, Workflows 5 04-26-2017 06:54 PM
Interpreting histograms? (color correct VHS) SimpsonsRule Restore, Filter, Improve Quality 8 05-07-2015 07:59 PM
Understanding HDR and Exposure Stops JasonCA Photo Processing, Scanning & Printing 5 03-04-2013 11:04 AM
Software filters in a nutshell, denoising and deinterlacing VHS video captures guokamoli Project Planning, Workflows 8 06-17-2011 08:08 PM
Understanding hardware strangepork Computers 1 10-19-2004 05:42 AM
