01-23-2019, 09:18 AM
colony colony is offline
Hello all,
I have a Core 2 Duo Windows XP (Home) workstation with AIW 9600 for capture, and am just starting to explore. Does it matter if I use VirtualDub 1.9.11 or 1.10.4 for VCR/Hi8 capture to AVI? Will it make a difference if I use huffYUV or huffYUV-MT; if so, which versions?
Lord Smurf posted the thread in Nov 2009 with downloads for the earlier VirtualDub, huffYUV and recommended filters. Is that or similar grouping of filters available separately/still current? Is there a reference out there for "which filters do what, etc."?
Regards
filters, huffyuv, virtualdub versions
VirtualDub with Filters Pre-loaded + HuffYUV [DOWNLOADS] lordsmurf Encode, Convert for discs 52 12-18-2025 12:18 PM
Huffyuv vs. Uncompressed? Need VirtualDub capturing help! VideoTechMan Capture, Record, Transfer 14 01-03-2016 05:06 AM
ATI MMC vs. VirtualDub, Huffyuv? Pinnacle vs ATI? SinghDk Capture, Record, Transfer 11 05-02-2015 04:07 AM
Reinstalling VirtualDub & HuffYUV for 64-bit system? rocko Encode, Convert for discs 6 02-21-2015 03:32 PM
HuffyUV Settings with VirtualDub for capture naripeddi Capture, Record, Transfer 7 04-12-2013 02:50 AM
