04-07-2004, 07:58 AM
jrnyhead jrnyhead is offline
How would you remove any black bars along the egde of the window (screen) before backing up a dvd?
04-07-2004, 10:09 AM
Why? Most of them are in the overscan and not seen on tv anyway...
Or is this a larger problem that is seen on tv?
04-07-2004, 10:47 AM
Well, no. On my pc screen I can see the black lines on each side of the monitor, but on the tv screen, their gone.
So, I guess it really isn't a problem.
04-07-2004, 12:26 PM
If this annoys you on the PC, most DVD player software will allow you to zoom in a bit.
How can i remove black bar from side of mpg?? Konfusion Restore, Filter, Improve Quality 12 11-27-2007 05:04 AM
Proper black level setup 777sp2 Capture, Record, Transfer 1 12-04-2005 04:14 PM
9800 AIW black & white prob manthing Capture, Record, Transfer 6 06-26-2005 06:48 PM
Why Black & White capture ? Sujit Capture, Record, Transfer 4 05-23-2005 08:27 AM
Black level (IRE) and YUV clamping talks admin Restore, Filter, Improve Quality 0 02-20-2005 03:54 PM
