05-16-2004, 12:46 AM
jrnyhead jrnyhead is offline
I know this might be a lame question, but I captured a wide screen segment and would like to know if I can convert it to full screen.
05-19-2004, 12:07 PM
Sorry for the delay, been replacing some blown out equipment (stupid power spike from storms).
Anyway, best thing to do is simply hit the ZOOM button on your DVD player. This is the best option.
If you really insist on cropping on and cutting off the sides, then re-encode the video in TMPGENC or some other video software that will let you crop into the image. If you want to do this (I don't suggest it, FYI), then let me know if you need help/images.
What lenses go on full frame DSLR's? beavereater Photo Cameras: Buying & Shooting 1 01-02-2009 02:17 AM
Screen Caps from Video shadowkaos Edit Video, Audio 8 10-26-2007 05:53 AM
Looking for a good 20 inch flat screen tv. MOTUfan Videography: Cameras, TVs and Players 0 08-25-2005 12:47 PM
Convert MPG to WAV w3tno Encode, Convert for discs 2 05-30-2005 03:17 AM
Convert to streaming MPEG format ? drumsys Encode, Convert for discs 1 04-19-2004 03:41 PM
