07-22-2006, 09:41 AM
angelofanimes angelofanimes is offline
I've been wondering about this for a long time, I have absolutely no idea how to do this, or how to encode it to make it anamorphic. The only thing I can do is add blocks to fit in "full screen" etc.
-AOA
07-22-2006, 10:16 AM
DVD only supports two aspect ratios... 16:9 and 4:3
Anything not fitting that exact dimension is padded with black in a matte.
For example, Justice League S2 release, is not an exact 16:9, it's bigger, and the video is matted into a 4:3 aspect video stream.
07-22-2006, 10:55 AM
So how should I encode this anamorphic AVI?
-AOA
07-22-2006, 11:24 AM
Matte it out to 4:3
TMPGEnc Plus does it automatically for you.
I think Procoder 2 will do it automatically too.
07-22-2006, 03:46 PM
Hmm, I don't think I understand what you mean by matte it out. (Using TMPEGnc PLUS). Am I supposed to use the CLIP FRAME? or the Aspect Ratio as you input the file? (4:3 Display)
-AOA
07-22-2006, 06:09 PM
cp32 cp32 is offline
Animorphic is okay for you wealthy folks with BIG SCreen Tv's.
But for the rest of the free world . Who only has 19 TV in their homes. It's a complete waste.
Just do it 16:9 if your going to be artsy about it
Less headache's too. Easy done in Tmpeg plus. Instead of 4 :3 aspect select 16:9 DVD
Personally, I prefer 4:3 I like to see the entire screen of what I m watching..
Now back to work management
07-22-2006, 10:14 PM
Krichton Krichton is offline
tmpgenc takes takes a year to convert something to anamorphic widescreen. Use a different program if you can. There should always be options for converting to 16:9
07-23-2006, 01:56 AM
What is your source? What are you attempting to do?
You must have widescreen content (true widescreen content, not partial widescreen), and 16:9 has to be used, and it only matters on a widescreen tv.
What tv do you want to watch this on?
07-23-2006, 09:05 AM
It's an AVI source, it has been cut into "widescreen" content, and I want to keep it widescreen when viewing on widescreen tvs, along with having blocks at the bottom and top when viewing in a full-screen tv.
640x336 is the resolution its in, I'm not sure if that's considered widescreen. There's also another file I have, and the resolution is is 512x288.
I also wanted to learn how to do anamorphic also, so this will help me in any other project. I have no idea what to convert it in.
-AOA
How to create mix DVDs, compilation DVDs? admin Edit Video, Audio 24 02-25-2010 03:03 PM
Editing old DVD to make new DVDs via Email or PM Edit Video, Audio 1 07-18-2009 04:50 PM
How to make a DVD montage mehrdad Encode, Convert for discs 20 06-27-2008 09:30 AM
How NOT to make a menu markatisu Author, Make Menus, Slideshows, Burn 5 09-03-2007 03:28 PM
How to make bad DVD copies lordsmurf Copy DVDs, Duplicate, Replicate 1 01-04-2006 11:58 AM
