11-23-2005, 01:58 AM
cp32 cp32 is offline
Okay, for those of us who lack patience for the pen tool. You do basically the samething with less work
"Custom Thumbnails made for TDA, the easy way; using adobe photoshop elements 2.0 "
You can create thumbnails as seen on phillips TDA Guide.
By using adobe photoshop elements 2.0 . Which you can download the trial vserion ( fully functional for 30 days).
I m terrible with the pen tool Okay , I ll say it. I just outright suck with the pen tool . Sooooo... after reading phil's guide . Some playing around with elements. Here's what ya do:
AAAAAAAAAAAAAAAAAAAAArey you ready.
Open 2.0
Depending on size of image you want to do.
I used the basic 720 x 540 then resized to my viewing pleasure
Just as phil stated.
open image -
duplicate ( must have 3 layers as phil stated )
just copy three times or create 3 new layers. Up to you.
Go to layers - select transparency-
to the left - layer style - select "Ghost" drag and drop to image or text. You want to use the effect on.
if you want to continue to be lazy. in layer effects - you can highlight by simple drag and drop . Or Open photoshop . I use 2.0 for this effect only The rest I use photoshop.
save 3 layers as psd . There ya go. Same results less work
Or for those of us who lack patience
Note : as philip stated in advanced mode make sure your second layer is not selected.
In plain engrish:
[u]"Your basically ghosting your text or image for the video to display throoooooooooooooogh it. "</u>
I ll try to post some screen caps to show what I did. LS I enclosed a disc of Hudson brothers razzle dazzle show. Using this method.
So you can see the results.
Maybe you can post some caps as well. should be there any day now?
12-03-2005, 02:04 AM
I used Elements for Thumbnails .Photoshop 7 for the menu.
Shot 66 the chapters are all custom thumbnails.
I used both methods. Text and shapes. .
Little mini Saw blades as well
Custom Thumbnails in TDA - Tutorial allaboutduncan Author, Make Menus, Slideshows, Burn 8 09-30-2005 12:15 PM
